Previous minor 3DEXPERIENCE platform updates
3DEXPERIENCE releaseHotfix levelDateContent
R2024x_FD04HF4.6 (SOLIDWORKS_3DEXP_Desktop)2024/11/06
- This HF fixes the issue of hole Wizard Position sketch becomes unabsorbed after closing part file and reopening
BR Reference: BR10000387677
R2024x_FD04HF 4.4 (SOLIDWORKS 3DEXP Elec C)2024/10/31
- With this HF, Issue of items not locking from the dialogs such as Manufacturer parts or electrical projects.
BR reference : BR10000387959
R2024x_FD04HF 4.4 (HF_XCADDesignConnectors )2024/10/31
- With this HF, Issue of getting Microsoft .NET Error while save as new using autoname has been resolved.
BR reference : BR10000383177
R2024x_FD04HF5.32 (HF_NativeApps_3DEXP_Cloud )2024/10/30
-This HF will resolve the issue related to revising physical product with a model version having only the version / options  feature.
BR Reference: BR10000388189
R2024x_FD04HF5.31 (HF_NativeApps_3DEXP_Cloud )2024/10/28
- This HF will improve the performance issues faced while running simulations involving overlapping of parts in Factory flow simulation, thus improving the overall stability.
BR Reference: BR10000388198
- This HF will also solve the issue of simulation of large data, thus improving the overall stability of the application.
BR Reference: BR10000388095
R2024x_FD04HF5.30 (HF_NativeApps_3DEXP_Cloud )2024/10/25- This HF fixed Corrections concerning save as new command
R2024x_FD04HF5.29 (HF_NativeApps_3DEXP_Cloud )2024/10/23
- This HF fixes, Cumulative snap doesn't work for some parts
BR Reference: BR10000367835
R2024x_FD04HF5.28 (HF_NativeApps_3DEXP_Cloud )2024/10/23-With this HF Referenceable process will not gets removed from reference adaptor process
R2024x_FD04
HF5.27
(HF_NativeApps_3DEXP_Cloud)
2024/10/18- This HF fixes, the issues related to ReplaceAll Function
R2024x_FD04
HF5.26
2024/10/18-This HF fixes, Parametric design study (PDS) is failing for all design points with Solidworks Data
R2024x_FD04HF 4.5 (SOLIDWORKS_3DEXP_Desktop)2024/10/16
- With this HF solidwork will not crash while dragging components in exploded assembly view
BR Reference: BR10000387504
R2024x_FD04HF 5.25 (HF_NativeApps_3DEXP_Cloud)2024/10/16
- This HF resolves the performance issue post-edition of a product with configured product, hence improving overall stability.
BR Reference: BR10000348202
R2024x_FD04HF 4.1 (3DEXPERIENCETransitionAssistant) 2024/10/14
  • With this HF, Issue of saved searches not listed in '3DEXPERIENCE Transition Assistant' tool has been resolved.
         BR reference : BR10000384025
  • With this HF, Issue of incorrect result displayed for assembly after analysis of data done has been resolved.
  • With this HF, Issue of migration failing for specific data has been resolved.
  • With this HF, 3DTA login performance issue has been resolved.
    BR reference : BR10000382173
  • With this HF, 3DTA PDM job creation issue failing issue has been resolved.
    BR reference : BR10000383176
  • With this HF, Issue of 3DTA PDM "Clear all jobs" command failing has been resolved.
    BR reference : BR10000382786
  • With this HF, Issue of Map revision and maturity from a SOLIDWORKS Custom Property leading to Maturity mapping error has been resolved.
  • With this HF, Issue of 3DTA PDM import failing issue with 'Object state not found for one child' error has been resolved.
    BR reference : BR10000384524
  • With this HF, Partial fix has been given for revision calculations.
R2024x_FD04
HF4.4
(HF_SOLIDWORKS_3DEXP_Desktop)
2024/10/14
-With this HF user will not face issue with batch save if has the same credentials (collaborative space and responsibility) in two companies
BR Reference: BR10000361778
R2024x_FD04HF5.24 (HF_NativeApps_3DEXP_Cloud) 2024/10/14BR10000387089 this will fix issue related to Door multi volumes distribution.
BR10000378659 this will fix a Crash issue during Derived Format generation.
BR10000384463 issue with conductor migration fixed
BR10000381075 Cable Symbol placement during wire representation is corrected.
BR10000380922 Modification Performance of shield symbols on a drawing is improved
R2024x_FD04HF5.23 (HF_NativeApps_3DEXP_Cloud ) 2024/10/10
-With this HF the issue of opening advanced Filter or Product on rich client is fixed.
BR Reference: BR10000387896
R2024x_FD04HF4.1(BIOVIA_DSMSPOWERBY )2024/10/05
-With this HF, output dcd and dsv files will not be truncated
BR Reference: BR10000383050
R2024x_FD04HF5.22 (HF_NativeApps_3DEXP_Cloud)2024/10/05
- With this HF, the issue of projection not working properly along with selection of correct element in sketcher is resolved.
BR Reference: BR10000381870
R2024x_FD04HF5.21 (HF_NativeApps_3DEXP_Cloud)2024/10/03
-This HF fixes the issue of Missing Description, translation define from knowledge rules.
BR Reference: BR10000386139
R2024x_FD04
HF5.20
HF4.2
(ENOVIADerivedFormatConverter)
2024/10/02
- With this HF, Issue of structures simulation submitted not consuming correct no of cores on grid has been fixed.
Also, the issue from physics apps, the save doesn't work for ‘Edit & Launch’ option in ‘external solve’ command when customized templates are used is also fixed
R2024x_FD04
HF5.19
2024/09/27- With this HF, Content Cannot be saved after Mountig to Axis System issue will be resolved.
BR Reference: BR10000387097
R2024x_FD04HF 5.18 (HF_NativeApps_3DEXP_Cloud )2024/09/26
- With this HF, Issue of crash when user wants to copy/paste or move a physical product with a drag and drop in design tree, has been resolved.
BR Reference: BR10000379290
R2024x_FD04HF 5.17 (HF_NativeApps_3DEXP_Cloud )2024/09/26
-This HF fixes the issues related to  Boolean type parameters handling during sync
BR Reference:BR10000382941
R2024x_FD04
HF5.16
2024/09/26
- This HF fixes the crash issue related to import of 3DXML and STEP file.
BR Reference: BR10000382293
R2024x_FD04
HF4.3
2024/09/25
- This HF fixes "Could not obtain the required license for SOLIDWORKS Connected"
BR Reference: BR10000386887
R2024x_FD03HF3.7 (HF_XCADDesignConnectors )2024/09/18
-With this HF, Error on selecting Maturity State in AutoCAD will be resolved
BR Reference: BR10000385437
R2024x_FD03
HF3.6
(HF_XCADDesignConnectors)
2024/09/04
-With this HF, Drag and Drop of components from My Session is allowed now in Solid Edge Assembly.
BR Reference: BR10000383094
R2024x_FD03HF 4.24 (HF_NativeApps_3DEXP_Cloud )2024/09/03
-With this HF, Time analysis card will start accepting negative values
BR Reference: BR10000379738
R2024x_FD03HF 4.23 (HF_NativeApps_3DEXP_Cloud )2024/08/29
- With this HF, Issue of Simulation run in additive manufacturing scenario creating native application has been resolved.
BR Reference: BR10000383230
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.222024/08/26
- This HF fixes Derived Format Converter crashed when generating pdf from DFC
BR Reference: BR10000378659
- This HF fixes Resolved items asking for an updated from Component Family(CF)
BR Reference: BR10000379484
R2024x_FD03HF 3.1 (CNT_NativeApps_3DEXP_Cloud )2024/08/22 - This HF solves issue related to Environment checks visibility from QRC
R2024x_FD03HF3.5 (HF_XCADDesignConnectors )2024/08/22
- This HF solves issue related to progress bar staying open even after check-in is complete.
BR Reference: BR10000380006
R2024x_FD03HF 3.4 (Collaborative Designer for X-CAD)2024/08/16
- This HF fixes the part save issue from Creo Connector
BR Reference: BR10000383078
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.212024/08/14
-This HF will resolve the issue related to filter of instances with effectivities in CA
BR Reference : BR10000382813
R2024x_FD03HF 3.1 (3DEXPERIENCETransitionAssistant) 2024/08/12-This HF will resolve issue related to Internally referenced files that are suppressed in the assembly are detected as User Defined References by the analysis
R2024x_FD03HF_XCADDesignConnectors - HF3.32024/08/12
-This HF will resolve Solid Edge Crash issue while deleting item from the assembly
BR Reference :BR10000378779
R2024x_FD03SOLIDWORKS_3DEXP_Desktop - HF3.52024/08/07
-This HF will resolve SOLIDWORKS crash issue during selection of section view and Display option
BR Reference:BR10000381986
R2024x_FD03HF NativeApps 3DEXP Cloud - HF4.202024/08/07
- This HF will resolve the issue of extending Evolution on multiple instance
BR Reference: BR10000380050
R2024x_FD03
HF_NativeApps_3DEXP_Cloud - HF4.19
SOLIDWORKS_3DEXP_Desktop - HF3.4
2024/08/06
- This HF has resolved the issue of Save with options window thus improving the performance of app.
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.182024/07/31
- This HF has solved the issue of generation of items in 'Test and Resolve Family Items' feature in case of component family.
BR Reference: BR10000380399
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.172024/07/29
-With this HF, Can provide CATIEdit extension to custom simulation solver feature
BR Reference : BR10000378174
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.162024/07/26-With this HF, Robot Detection command will work OK
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.152024/07/25
-This HF resolves the issue related to interference result for RVT project filter
BR Reference :BR10000378011
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.13 2024/07/22
- This HF resolves the issue related to import of 3DXML in native app
BR Reference: BR10000381235
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.122024/07/20
-This HF resolves the issue related to copy/paste of Physical Product in design tree
R2024x_FD03SOLIDWORKS_3DEXP_Elec_C - HF3.12024/07/17-This HF will resolve issue related to visibility of active Alternative
R2024x_FD03HF_NativeApps_3DEXP_Cloud - HF4.112024/07/17
-This HF will resolve problem related to versioning mechanism & selection command
BR Reference: BR10000364804
R2024x_FD03HF 4.10 (HF_NativeApps_3DEXP_Cloud )2024/07/16- This HF will resolve the crash issue of Curve evaluator command and provide better performance and stability.
BR Reference: BR10000377441
R2024x_FD03
HF4.9
2024/07/16
-With this HF, VR usage in Creative Experience shows lags and glitches during VR session has been resolved
BR reference: BR10000375845
R2024x_FD03HF 3.3 (SOLIDWORKS_3DEXP_Desktop)2024/07/11
- With this HF, Solidworks connected launch issue of a customer working is cross company has been resolved.
BR reference: BR10000381831
R2024x_FD03HF 4.8 (HF_NativeApps_3DEXP_Cloud )2024/07/11- This HF resolves the performance issues faced while importing data model thus optimizing the overall stability.
R2024x_FD03HF 4.7 (HF_NativeApps_3DEXP_Cloud )2024/07/11- This HF resolves the performance issue faced while executing results for models with substructure thus improving the performance of the simulation.
R2024x_FD02ENOVIADerivedFormatConverter - HF2.3
HF_XCADDesignConnectors - HF2.3
2024/06/25
- This HF fixes the Issue on drawing template during export under PDF.
BR reference: BR10000378676
R2024x_FD02HF 3.20 (HF_NativeApps_3DEXP_Cloud )2024/06/21
- This HF fixes the Wireframe elements selection issue when using Display Wireframe and Axis function.
BR reference: BR10000374413
R2024x_FD02HF 2.1 (BIOVIA_DSMSPOWERBY )2024/06/17- This HF fixes the crash issue occurred while login to the app, thereby improving the stability and performance issue.
R2024x_FD02
HF 2.3
2024/06/07
- With this HF, issue of 3DTA import Job stuck in status 3 (Under Export) when Assembly has same reference at Top Level and in a Internal Assembly is fixed
BR reference : BR10000375297
R2024x_FD02HF 3.19 2024/06/03
- With this HF, overall stability of CATIA quality rules has improved.
BR reference : BR10000368881
R2024x_FD02HF 3.18 (HF_NativeApps_3DEXP_Cloud)2024/05/31
- This HF fixes the issue of facing latency for the operation drag,zoom when expanded all assembly in session
Reference BR: BR10000374601
R2024x_FD02HF 3.17 (HF_NativeApps_3DEXP_Cloud)2024/05/30
- This HF fixes the issue of renaming publications created with Capture Component Specification in Building 3D Design App.
Reference BR: BR10000375425
R2024x_FD02
HF 3.16
2024/05/26
- With this HF, Issue of fix command not working in component family has been fixed.
Bug Report - BR10000375762
R2024x_FD02
HF2.3
2024/05/23
-This HF will resolve the issue of Bookmarks are disconnecting from the Design Library after deleting
Bug Report - BR10000370669
-This HF will resolve the issue of Save as/MBD Publish to 3DPDF does not create file
Bug Report - BR10000377339
R2024x_FD02
HF 3.15
2024/05/23-This HF fixes bad convergence for exhaust cases
R2024x_FD02
HF 3.14
2024/05/22
- This HF fixes Broken link between PT and excel file, While editing product table with edit sheet throws error.
Reference BR: BR10000374616
R2024x_FD02HF 3.132024/05/21
- This HF fixes the issue where previously saved updates in attribute values are lost after reopening the data in a new session.
Reference BR: BR10000365982
R2024x_FD02HF2.2 (ENOVIADerivedFormatConverter )2024/05/17- With this HF, Derived Format Converter launch issue has been fixed.
R2024x_FD02HF 3.12
HF_NativeApps_3DEXP_Cloud - HF3.12
2024/05/15
- With this HF the issue of 2D Layout main view as an input in a Design Sequence will be fixed
Bug report:: BR10000377183
R2024x_FD02
HF2.2
2024/05/11
- With this HF the issue of CAD connectors (Inventor, AutoCAD) stopped working will be fixed
Bug report:: BR10000376912
R2024x_FD02
HF3.11 (HF_NativeApps_3DEXP_Cloud)
HF2.1 (ENOVIADerivedFormatConverter )
2024/05/13- This HF improves overall stability of 3DExperience Platform as described in BR10000362809
R2024x_FD02HF3.10 (HF_NativeApps_3DEXP_Cloud)2024/05/07
- With this HF, Issue of FEM instability after FD 02 update has been resolved.
- With this HF, Performance issue of mesh generation has been resolved.
Bug report: BR10000375817
R2024x_FD02HF3.9 (HF_NativeApps_3DEXP_Cloud)2024/05/06
- This HF will resolve the issue of reinforcement reports and their missing values.
Bug report: BR10000373659
- This HF will resolve the issue related to Multi-Discipline Drafting Annotation and dimension placement.
Bug report:  BR10000374683
R2024x_FD02HF3.8 (HF_NativeApps_3DEXP_Cloud)2024/05/03
- This HF has improved the stability of 3DEXPERIENCE Platform while importing 3DXML as reference.
Bug Report: BR10000375497
R2024x_FD02
HF 2.2
2024/04/28This HF fixes the license error while launching SOLIDWORKS Connected for user with access on expired environment.
R2024x_FD01HF1.31 (HF_NativeApps_3DEXP_Cloud )2024/04/25- With this HF Import 3DXML As Reference With Reidentification will not result in crash
R2024x_FD01HF1.30 (HF_NativeApps_3DEXP_Cloud - HF1.30)2024/04/22This HF improves overall stability of 3DExperience Platform.
R2024x_FD01HF1.28 (HF_NativeApps_3DEXP_Cloud)2024/04/16With this HF, overall stability of Native apps is improved
R2024x_FD01HF1.27(HF_NativeApps_3DEXP_Cloud)2024/04/02-This HF will solve the performance issues thus optimizing the operations of the app.
R2024x_FD01HF1.26(HF_NativeApps_3DEXP_Cloud )2024/03/29
-This HF will resolve the issue related to editing of Electrical branch and opening of 3DShape.
Bug Report: BR10000374385
R2024x_FD01 HF1.24(HF_NativeApps_3DEXP_Cloud)2024/03/26
-This HF will resolve the issue related to Product Processor Optimization in CATIA Rendering Scene Design app
Bug Report: BR10000372897
R2024x_FD01HF1.23(HF_NativeApps_3DEXP_Cloud )2024/03/22
-This HF will resolve the issue related to losing of annotations created on Master product level in resolved component family assembly.
Bug Report: BR10000368015
R2024x_FD01HF 1.22(HF_NativeApps_3DEXP_Cloud )2024/03/16
-This HF resolves the issue related to IFC Export
Bug Report: BR10000372081
R2024x_FD01HF1.2 (3DEXPERIENCETransitionAssistant)2024/03/14- This HF fixed the issue of  Duplicate file names in same 3DTA job cause the job to fail
Bug Report BR10000370198
R2024x_FD01HF 1.21 (HF_NativeApps_3DEXP_Cloud)2024/03/08
- This HF will resolve the performance issues faced while using 3DShape thus reducing the time taken to open a model.
Bug Report: BR10000372908
R2024x_FD01
HF 1.5
2024/03/08
-This HF fixes 'Use Title as Filename' and 'Use Name as Filename' are not available in SOLIDWORKS Connected 'Pack and Go' Dialog
Reference BR: BR10000371633
R2024x_FD01HF1.20 (HF_NativeApps_3DEXP_Cloud)2024/03/07
- This HF improves the computation of bead fastener by assuming that the bead part is the fastener itself when there is no bead part.
Reference BR: BR10000372526
R2024x_FD01HF1.1 (TEC_CEF_C)2024/03/06With his HF update, Zero-day vulnerability in Google Chrome is fixed
R2024x_FD01HF1.19 (HF_NativeApps_3DEXP_Cloud )2024/03/06- - With his HF update iso panel will not result in crash
R2024x_FD01HF1.18 ( HF_NativeApps_3DEXP_Cloud )2024/03/04-  With this HF, Native app crash issue will be resolved
R2024x_FD01HF 1.3 (HF_XCADDesignConnectors)2024/02/29- With this HF, Issue of seeing unmodified objects as well in save dialog box when we enable save optimization from tools > options has been resolved.
R2024x_FD01HF1.17 (HF_NativeApps_3DEXP_Cloud)2024/03/01-This HF resolves missing contours in Durability cases.
- This HF resolves wrong Material Parameter values in formula command.
R2024x_FD01HF 1.16 (HF_NativeApps_3DEXP_Cloud )2024/02/28
- This HF fixes the issue of consumption of different instances under different CAs in MBOM on NativeApps.
Reference BR: BR10000369947
R2024x_FD01
HF 1.4
2024/02/26-This HF resolves the issue of the long upgrade install time.
R2024x_FD01HF0.38 (HF_NativeApps_3DEXP_Cloud )2024/02/26
- This HF will allow for correct volume measure computation in measure item function of Native App.
Reference BR: BR10000367368
R2024x_FD01
HF 1.3
2024/02/26-This HF resolves the issue encountered when saving an assembly. The modified assembly will be shown only in the save dialog box and unmodified objects wont appear in save dialog box thus optimizing the functionality.
R2024x_FD01HF 1.15 (HF_NativeApps_3DEXP_Cloud )2024/02/26-This HF resolves the error encountered when using Feature.Delete() api in Component Family Resource automatically and EKL code issues providing better performance and functioning.
Bug Report: BR10000371542
R2024x_FD01
HF1.14
2024/02/23-This HF resolves the issue opening a FEM crashes the application BR10000368426
R2024x_FD01HF1.13 (HF_NativeApps_3DEXP_Cloud) 2024/02/22-This HF solves instantiation issue of Engineering template. BR10000371834
R2024x_FD01
HF1.12
2024/02/22
- This HF solves the performance issue encountered during import of terrain files, thus reducing the time during this process.
- This HF will improve the performance issue encountered during Change Level of Development command operation hence optimizing the process.
Bug Report: BR10000371430
- This HF will enable CBD to instantiate TPL which will duplicate the table on each products instantiated.
Bug Report: BR10000369635
R2024x_FD01HF1.11
2024/02/20
-This HF resolved a crash issue while editing a line fastener in 3Dexperience Model Creation app
Bug Report: BR10000368518
R2024x_FD01HF1.10
2024/02/16-This HF resolves the issue of PP Instruction empty
R2024x_FD01HF1.2 (SOLIDWORKS_3DEXP_Desktop & XCADDesignConnectors)2024/02/15
-This HF fixes Solidwork crash issue while saving objects to platform.
Bug Report: BR10000371342
R2024x_FD01HF 1.9 (HF_NativeApps_3DEXP_Cloud )2024/02/15
-This HF fixes CATIA freeze issue after startup due to GarbageCollector
- With this HF VR performance will be improved by deciding how visibility is switched
R2024x_FD01HF1.7 (HF_NativeApps_3DEXP_Cloud )2024/02/14- With this HF, Issue of slow performance when selecting line or grid for Structural commands has been resolved.
R2024x_GAHF0.37 (HF_NativeApps_3DEXP_Cloud )2024/02/06
- This HF fixes configurations disappear when you open an assembly resolved in resulting product
Reference BR: BR10000367183​​​​​​​
R2024x_GAHF0.36 (HF_NativeApps_3DEXP_Cloud )2024/01/30
- With this HF Components Family link with released item will not be lost
Reference BR: BR10000366038
R2024x_GAHF 0.35 (HF_NativeApps_3DEXP_Cloud)2024/01/25
- This HF will enable to run the documentation process correctly. This will help to detect Standard XML file in standard resources on FTA and electrical manufacturing preparation and complete the process effectively.
Reference BR: BR10000365719
R2024x_GAHF0.34 (HF_NativeApps_3DEXP_Cloud )2024/01/24This HF will resolve GetDesignQualityResult() API call issue
R2024x_GAHF0.1 (ENOVIADerivedFormatConverter)2024/01/18
This HF will resolve sudden stoppage of Derived Format Converter processes due to session invalidation.
Reference BR: BR10000367959​​​​​​​
R2024x_GAHF0.33 (HF_NativeApps_3DEXP_Cloud)2024/01/18This HF allows for a measurement update between a PAD and a geometry.
Reference BR: BR10000366563
R2024x_GAHF0.8 (HF_XCADDesignConnectors)2024/01/18This HF fixes the creation of a thumbnail or a preview when saving Inventor drawings.
Reference BR: BR10000363869​​​​​​​
R2024x_GAHF0.32 (HF_NativeApps_3DEXP_Cloud)2024/01/16
- This HF will resolve the issue of crashing of app if invalid material was used to import a model. The user will be able to perform a PLM update and app wont crash even after selection of invalid material.
Reference BR: BR10000365528
- This HF will improve the overall performance and would help save some time to open simulate dialog thus reducing the time taken to do so.
- This HF will improve the overall stability of the Physics Results Explorer app.
R2024x_GAHF0.31 (HF_NativeApps_3DEXP_Cloud)2024/01/12
- With this HF, Performance issue of data loading in DELMIA has been resolved.
Reference BR: BR10000367930
R2024x_GAHF0.7 (HF_XCADDesignConnectors)2024/01/11- THIS HF will fix the issue of extra material added when generating shape
R2024x_GAHF0.30 (HF_NativeApps_3DEXP_Cloud)2024/01/11
BR10000362562
- THIS HF will fix Inventor physical property values mapped to 3DEXPERIENCE gone through wrong  conversion during synchronization while save from Inventor to 3DEXPERIENCE
R2024x_GAHF0.29 (HF_NativeApps_3DEXP_Cloud)2024/01/09
-This HF will eliminate the discrepancy in ZMin. Correct ZMin will be displayed after creation of macro in VSTA.
BR10000363871
-This HF will fix the issue of drag and drop button. This HF will enable the option of drag and drop button in the activities process view.
R2024x_GA(HF 0.28)HF_NativeApps_3DEXP_Cloud2024/01/05
This HF will fix issue related to measure between the two circular edges
BR10000367066
R2024x_GA(HF0.6)HF_XCADDesignConnectors2024/01/08
This HF will fix error '"CheckoutEx request to build reference tree failed..." during action 'Reload file and references'
BR10000364467​​​​​​​​​​​​​​
R2024x_GA(HF 0.27)HF_NativeApps_3DEXP_Cloud2024/01/04
-This HF will fix the issue of import of 3dxml. This will enable the user to import the attached 3dxml without any error.
BR10000367242
R2024x_GA(HF0.26)HF_NativeApps_3DEXP_Cloud2023/12/22- With this HF Port Routing implemented for Two point port Part in New flex UI.
BR10000365212
R2024x_GA(HF0.25)HF_NativeApps_3DEXP_Cloud2023/12/20
Create/Update Item Structure command in Manufactured Item Definition App will finish loading and will generate the manufacture items
BR10000365994​​​​​​​
R2024x_GAHF_NativeApps_3DEXP_Cloud - HF0.242023/12/19
- This HF will fix the issue of generation of resolved assembly identical to that of existing one during revising. This will enable user to generate a resolved assembly MVB identical to the MVA when revising.
Reference BR: BR10000366071​​​​​​​
R2024x_GAHF0.10 (3DEXPERIENCE SOLIDWORKS Desktop)2023/12/18
- This HF fixes the issue faced while using  'Reload from Server' command during asynchronous save.
Reference BR: BR10000364467
R2024x_GA(HF0.23)HF_NativeApps_3DEXP_Cloud2023/12/15
- This HF fixes Automatic positioning of Annotations using EKL
Reference BR:BR10000364178​​​​​​​
R2024x_GA(HF0.9)SOLIDWORKS_3DEXP_Desktop2023/12/14
- This HF fixes Solidworks freeze issue while selecting a component instance (FeatureManager Design Tree or Graphics Area) within a Mirror Component assembly feature that has been previously created within an earlier Mirror Component assembly feature.
Reference BR: BR10000365515
R2024x_GA(HF0.21)HF_NativeApps_3DEXP_Cloud2023/12/12
- This HF fixes the issue to create a measure between two points in ENOVIA Design Review
Reference BR: BR10000362006
R2024x_GA(HF0.8)SOLIDWORKS_3DEXP_Desktop2023/12/11
- This HF fixes the issue where, Derived component part shows an erroneous assembly icon as a child object which causes MySession to become blank when the parent assembly is open or switching windows.
Reference BR: BR10000365059
R2024x_GA(HF0.5)HF_XCADDesignConnectors2023/12/11
- With this HF, swcefcache folder location is changed from user’s AppData folder to user’s Temp folder.
- This HF fixes coexistence crash while saving an assembly with a derived xShape component
- This HF fixes the 3DEXPERIENCE connection issue when launching from SOLIDWORKS Connected when user has access to more than 200 collaborative spaces.
Reference BR: BR10000362116
R2024x_GA(HF0.20)HF_NativeApps_3DEXP_Cloud2023/12/07-This HF fixes the issue while selecting
the points at the center of fibres and setting a tolerance which correspond the radius of fibres, line of the fibre axis & the proximity group selection in a boolean group
R2024x_GA(HF0.19)HF_NativeApps_3DEXP_Cloud2023/12/07
- With this HF, issue related to replacing of data once the data is in frozen effectivity has been fixed and the data cannot be replaced hence better data protection.
BR Reference: BR10000363133
R2024x_GA(HF0.18)HF_NativeApps_3DEXP_Cloud2023/12/06
- With this HF, issue related to disconnected volumes in Wall feature has been fixed.
BR Reference: BR10000364877
R2024x_GA
( HF0.17) HF_NativeApps_3DEXP_Cloud
( HF0.4) HF_XCADDesignConnectors
(HF0.1) SCM_Connectors
(HF0.1) TEC_CEF_C
2023/12/01
- With this HF, Error while installing app that uses the DS Installer when Microsoft Visual C++ 2015-2022 Redistributable is not installed has been fixed.
R2024x_GA(HF0.3) HF_XCADDesignConnectors2023/11/28
With this HF, following issues will be fixed:
Unable to Select Bookmark folder while saving from CREO
BR reference : BR10000363375
R2024x_GA(HF0.16) HF_NativeApps_3DEXP_Cloud2023/11/27
With this HF, following issues have been fixed:
- "Find" API function should not modify the material. Reference BR: BR10000358546
- Running simulation checks leads to errors. Reference BR: BR10000363059
- Enhance code to deal with multi-elements per bolt
- Problem with the method of comparing effectivities. Reference BR: BR10000363310
R2024x_GASOLIDWORKS_3DEXP_Desktop - HF0.72023/11/24
Reference BR: BR10000364877
R2024x_GAHF0.14 (HF_NativeApps_3DEXP_Cloud)2023/11/23
- With this Import of minor revisions is forbidden issue will be resolved.
Reference BR-BR10000356395
R2024x_GAHF0.6 (SOLIDWORKS_3DEXP_Desktop)2023/11/23
With this HF, SOLIDWORKS Connected crash issue due to appearance of white-box when entering sketch dimension value with Microsoft IME(Japanese input mode) has been fixed.
Visualize Connected - 2024 can load some .svpj if they are saved from some versions of 2023.
No more error message " The system cannot find the specified file" while launching SOLIDWORKS Connected on a different OS language.
Reference BR:
R2024x_GAHF0.13 (HF_NativeApps_3DEXP_Cloud)2023/11/21
With this HF, issue with profile management in Solidworks that clashed with wrong setting declaration, has been resolved.
Reference BR-BR10000364646
R2024x_GAHF0.12 (HF_NativeApps_3DEXP_Cloud)2023/11/20
 With this HF, Issue of product table not changing/updating the design when "apply row" is selected, has been resolved.
Reference BR-BR10000365200
R2024x_GAHF0.2 (HF_XCADDesignConnectors)2023/11/16-This HF will fix the error while opening recently saved design (including Schematics) in Altium Designer.
R2024x_GAHF0.11 (HF_NativeApps_3DEXP_Cloud)2023/11/15-This HF will fix the issue with Module - Icon in SpecTree still have the "hide" mask when switching the Alternative
R2024x_GAHF0.10(HF_NativeApps_3DEXP_Cloud )2023/11/10
-This HF fixed Change of behavior on the input bloc while pointing at a geometrical set inside of the published geometries of another design sequence.
Reference BR-BR10000364804
R2024x_GAHF0.7(HF_NativeApps_3DEXP_Cloud)2023/11/09-This HF will fix issue with 3DSVideoRecord while creating 3DPart
R2024x_GAHF0.5(SOLIDWORKS_3DEXP_Desktop )2023/11/07- This HF has improved the overall stability of SOLIDWORK's xDesign.
R2023x_FD04HF 4.9 (SOLIDWORKS_3DEXP_Desktop)2023/10/26
- With this HF, Issue of SOLIDWORKS connection launch issue while having more than 200 collaborative spaces has been resolved.
Reference BR- BR10000362116
R2023x_FD04HF4.25 (HF_NativeApps_3DEXP_Cloud )2023/10/24This HF will resolve the issue in action "MBOM Synchronize Configuration" does not run and the session crashes and creates minidumps
R2023x_FD04HF 4.8 (SOLIDWORKS_3DEXP_Desktop)2023/10/21With this HF, following issues are resolved:
1. Object ID not handled properly for baseline with component instances
2. Component Addition in case of IDX3.0 file to change Subtype 1 to Add and Subtype 2 to Component
3. Object id change issue in case of IDX3.0 file
4. Hole Rejection is not working properly when try to process the response
5. Keepout related layer gets changed in SW model
6. KeepOut shape change as part of KeepOut modification in CW in case of IDX3.0 file
R2023x_FD04HF4.24 (HF_NativeApps_3DEXP_Cloud )2023/10/20In this Fix, support for multiple elements per bolt has been implemented in simulation
R2023x_FD04HF4.23 (HF_NativeApps_3DEXP_Cloud )2023/10/18
This HF fixes Loss of EBOM evolution effectivities data when launching Synchronize  Evolution without Variables
Reference BR- BR10000363137
R2023x_FD04HF4.22 (HF_NativeApps_3DEXP_Cloud )2023/10/17
-Issue related to update of measurement for hidden geometry has been fixed.
Reference BR- BR10000358293
R2023x_FD04HF4.21 (HF_NativeApps_3DEXP_Cloud )2023/10/16
-With this HF, When launching the simulation on the "Copy Operator" activity, both the toolpath line as well as the material depositied along the toolpath will simulate and shown.
Reference BR-BR10000360603
R2023x_FD04HF4.7(SOLIDWORKS_3DEXP_Desktop )2023/10/12
- With this HF, Issue of visualize images losing appearance when the base geometry is updated in SOLIDWORKS and then updated to latest visualize.
Reference BR BR10000356706
- With SOLIDWORKS in a Foreign Language, once the part with properties is exported in STEP format, the mass property value changes. With this HF, this issue has been fixed.
Reference BR BR10000360608
R2023x_FD04HF4.20 (HF_NativeApps_3DEXP_Cloud)2023/10/12
-Corrupted entities are filtered before copying slide in Product Markup
Reference BR BR10000357370
R2023x_FD04HF4.2 (XCADDesignConnectors)2023/10/06
-Error during batch save due to matching credentials in 2 companies has been resolved.
Reference BR  BR10000361778
R2023x_FD04HF4.19 (HF_NativeApps_3DEXP_Cloud)2023/10/05
- With this HF, Issue of Impossible to propagate after copy paste data with material has been resolved.
Reference BR  BR10000358546
- With this HF, Issue when updating a feature after undo has been resolved.
R2023x_FD04HF4.2 (ENOVIADerivedFormatConverter )2023/10/04The submitted derived output job for the modified SOLIDWORKS SLDPRT with multiple configuration(s) to linkable ExactGeometry conversion will successfully get processed through ConversionAdmin service
R2023x_FD04
HF4.18 (HF_NativeApps_3DEXP_Cloud)
2023/10/05The submitted derived output job for the modified SOLIDWORKS SLDPRT with multiple configuration(s) to linkable ExactGeometry conversion will successfully get processed through ConversionAdmin service
R2023x_FD04HF4.6(SOLIDWORKS_3DEXP_Desktop )2023/10/02
This HF Fixes Errors 'Unable get collaborative spaces' and 'ERROR: 3DEXPERIENCE server not defined' when using Batch Save to 3DEXPERIENCE if user has the same credentials (collaborative space and responsibility) in two companies
R2023x_FD04HF4.1 ( ENOVIADerivedFormatConverter)2023/09/29With this HF connection fails issue will resolve in Derived Format Converter
Reference BR :  BR10000356417
R2023x_FD04HF4.17 (HF_NativeApps_3DEXP_Cloud)2023/09/28With this HF , Point fastener will not fail while updating in FD03 and FD04
R2023x_FD04HF4.162023/09/26
This HF Fixes Spreadsheet Editor import function does not create instances of existing  cable/wires correctly in the tree
Reference BR  BR10000359962
R2023x_FD04HF4.1 (3DEXPERIENCETransitionAssistant)2023/09/22with this HF : Successfully imported jobs will not get resent ,also will not split.
R2023x_FD04HF4.5(SOLIDWORKS_3DEXP_Desktop )2023/09/19
This HF fixes Issue with SOLIDWORKS Crashes while opening the assembly
Reference BR  BR10000358840
R2023x_FD03HF3.242023/09/13
This HF fixes session freeze issue during Import of CATIA V5 CATParts file
Reference BR  BR10000356919
R2023x_FD03HF3.232023/09/12
This HF fixes error message when trying to add effectivities
Reference BR  BR10000357384
R2023x_FD03HF3.1 (SOLIDWORKS_3DEXP_Elec_C)2023/09/11Mandatory update to avoid any issue after R2023x FD04 upgrade with the Electrical Schematic Design application.
R2023x_FD03HF3.7 (SOLIDWORKS_3DEXP_Desktop )2023/09/08with this HF : Can save assembly  components controlled by Change Action (CA) are in save scope
Reference BR  BR10000357553
R2023x_FD03HF3.5 (XCADDesignConnectors)2023/09/07
This HF Fixes the issue 'Save' button is grayed out and assembly cannot be saved because components under Change Action (CA) in save scope are owned by another person and cannot be locked
Reference BR:BR10000357553
R2023x_FD03HF3.222023/09/05
With this HF,  issue's of 3DR visualization after a local save or propagation are corrected
Reference BR:BR10000350764
R2023x_FD03HF3.212023/08/31
With this HF, Estimate of simulation licenses would be correct
Reference BR:BR10000358843
R2023x_FD03HF3.20  2023/08/29With this HF , In Creative Experience, The published experience will be optimized and the original experience will not get modified
R2023x_FD03HF 3.4 (Collaborative Designer for X-CAD)2023/08/24-With this HF, the Discipline attribute dependency for Revit PowerBy connector has been removed
R2023x_FD03HF 3.192023/08/18-With this HF, Planets env will not get stacked in twin editor and crash will not occurs on configuration change.
R2023x_FD03HF 3.182023/08/11
-With this HF, Trying to open results stored on the cloud will not causes a client crash
Reference BR : BR10000358217
R2023x_FD03HF 3.172023/08/09
-With this HF ,New API 'GetPointCloudElement' is provided.
Reference BR:BR10000349038
R2023x_FD03HF 3.162023/08/08
-This HF has improved the stability of native apps
Reference BR:BR10000353146
R2023x_FD03HF 3.152023/08/07
- With this HF, Issue of overloaded engineering connections not well managed by product table has been fixed.
Reference BR:BR10000355368
R2023x_FD03HF 3.142023/08/03
- This HF fixes the issue china performance issue while trying to open a product in native app
Reference BR:BR10000356512
R2023x_FD03HF 3.132023/08/03
- This HF fixes the issue where after changing roles from owner to leader, content creation from template is not possible.
Reference BR: BR10000352733
R2023x_FD03HF 3.122023/07/31
-With this HF Synchronize All UDF will work if UDF are linked to an xGen design sequence
Reference BR: BR10000355816
R2023x_FD03HF3.1 (Connector for Artwork CopyAI)2023/07/27-With this HF , The mapping will no more lost on the Text Area after clicking 'Undo Move' command in AI Connector.
R2023x_FD03HF3.1[3DEXPERIENCETransitionAssistant]Coming soon- This HF improves the overall stability of 3DEXPERIENCE Transition Assistant. It is highly recommended that this HF is deployed before any import is initiated.
R2023x_FD03HF3.6[SOLIDWORKS_3DEXP_Desktop ]2023/07/26
-This HF Fixes, Cannot publish or save a sheet format (*.slddrt) from SOLIDWORKS Connected since R2023x FD03 update
Reference BR: BR10000356851
R2023x_FD03HF 3.112023/07/22
- This HF Fixes, Healing function in Assessment Report of the profile
Reference BR: BR10000357234
R2023x_FD03HF 3.102023/07/21
- This HF fixes the Private station starting issue after 23x FD03 upgrade.
Reference BR: BR10000356649
R2023x_FD03HF3.1 [CollaborationforMicrosoftClient ]2023/07/13
- With this HF MS Project will show correct Estimated dates
BR10000351458
R2023x_FD02HF2.232023/06/23
-With this HF, CATIA crashes after use of position all command Fixed.
Reference BR- BR10000352464
R2023x_FD02HF2.222023/06/19
-With this HF, Copy Paste operation on Publication fails with Error "The feature naming is incomplete." Fixed
Reference BR-BR10000347558
R2023x_FD02HF2.1 (ENOVIADerivedFormatConverter)2023/06/14
 This HF Fixes  Asynchronous STEP derived output conversion fails with SOLIDWORKS Connected / SOLIDWORKS 2023
Reference BR-BR10000349906
R2023x_FD02HF 2.212023/06/12
-With this HF, measurement issue of join surface has been resolved
Reference BR-BR10000349829
R2023x_FD02HF 2.202023/06/09
-With this HF, Issue of requirement browser not displaying the parameter attributes values as defined has been fixed
Reference BR-BR10000346374
R2023x_FD02HF 2.192023/06/08
- With this HF, Issue of not showing current toolpath after a recalculation has been fixed.
Reference BR : BR10000350701
R2023x_FD02HF 2.182023/06/07
-With this HF,
 Issue of fix coupling for blind hole has been fixed
R2023x_FD02HF 2.172023/06/02
- With this HF, Impossible to run several command issue has been fixed
Reference BR : BR10000353158
R2023x_FD02HF 2.142023/05/22- Rollback of the HF2.15
R2023x_FD02HF 2.152023/05/19
- This HF fixes the performance issue while exploring the filter in Native Apps
Reference BR: BR10000348112
R2023x_FD02HF 2.142023/05/13- With this HF, Issue of Personalized icons getting lost after opening a Machining cell has been fixed
R2023x_FD02HF 2.132023/05/12
- With this HF, Issue of getting license error message while launching Native Apps (EKL action issue) has been resolved.
Reference BR: BR10000351113
R2023x_FD02HF2.2 (SOLIDWORKS_3DEXP_Desktop)2023/05/10-With this HF, Issue with using asynchronous interactive save has been fixed
R2023x_FD02HF2.2 (Collaborative Designer for X-CAD)2023/05/09-With this HF, Issue of description column goes blank for objects while saving data using asynchronous interactive save has been fixed
R2023x_FD02HF 2.1 (Collaboration for Microsoft Client )2023/05/09
-This HF Fixes Opening project in MS Project & creating task taking long time
Reference BR: BR10000350481
R2023x_FD02HF 2.122023/05/05
- With this HF, Issue of hidden geometry taking into account in the measurement has been resolved.
Reference BR: BR10000348269
R2023x_FD02HF 2.112023/05/02
- This HF fixes the issue of missing objects from the Views in 3DWorkbook.
Reference BR: BR10000347383
R2023x_FD02HF 2.102023/04/28
-This HF Fixes in  Structural Model Creation app, PLM Update for small change to one connection takes excessive time to complete
Reference: BR10000349172
R2023x_FD02HF 2.92023/04/27
-With this HF, The effectivity (local effectivity) gets applied to all selected instances in tree.
Reference : BR10000349738
R2023x_FD02HF 2.82023/04/23- Published data from 3DDrive are well loaded in search embeded in Native apps.
R2023x_FD01HF 1.252023/04/18- This HF fixes the crash issue faced when using volatile ghosting in multi-roots mode.
R2023x_FD01HF 1.242023/04/15
- With this HF, Issue of Customized Edit Effectivity Command, not applicable on multi-instances selection has been fixed.
R2023x_FD01HF 1.232023/04/13
-This HF fixes the save issue by correcting path id in cache. [highly recommended]
Reference : BR10000347285
R2023x_FD01HF 1.222023/04/05
-This HF fixes the CONFIG_DATA_INTEGRITY_ERROR on deleting the part
Reference BR: BR10000348309
R2023x_FD01HF 1.212023/04/03
- This HF fixes the synchronization issue with external link to Axis System from User Defined Feature.
Reference BR: BR10000347826
R2023x_FD01HF 1.202023/03/30
- This HF fixes the 3DXML Export issue with split option.
Reference BR: BR10000345828
R2023x_FD01HF 1.192023/03/28
- This HF fixes the CATIA crash issue when using link spreadsheet.
Reference BR: BR10000347084
R2023x_FD01HF 1.182023/03/24
- This HF fixes the issue of unintended requests and load when opening and closing the "Visual Scripting Editor" UI.
Reference BR: BR10000347584
R2023x_FD01HF 1.172023/03/23
- This HF fixes the errors received during running a simulation.
Reference BR: BR10000347122
R2023x_FD01HF 1.162023/03/22- With this HF, overall stability of Native apps is improved.
R2023x_FD01HF 1.152023/03/20
- With this HF, Issue of loosing the connection to the values while applying FTA annotations has been fixed.
Reference BR: BR10000348436
R2023x_FD01HF 1.142023/03/16
- This HF fixes the issue where Documentation generated by Macro but not saved at Manufacturing Cell Level, with message “Cast Error”
Reference BR: BR10000347649
R2023x_FD01HF 1.132023/03/15
- With this HF, Issue of multi-instances selection not applicable with Customized Edit Effectivity Command has been fixed.
Reference BR: BR10000347384
R2023x_FD01HF 1.122023/03/13
- This HF fixes the issue of data export with "Convert Part As Specification" option.
Reference BR: BR10000347795
R2023x_FD01HF 1.112023/03/11- Issue of bad result when executing a Profile with check PLMUpdate is fixed with this HF.
R2023x_FD01HF 1.102023/03/10
- This HF fixes the issue where Product Processor removes geometry during optimization run.
Reference BR: BR10000347471
R2023x_FD01
HF 1.2 (
2023/03/06
- This HF fixes the released component save issue.
Reference BR: BR10000346924
R2023x_FD01HF 1.92023/03/03
- This HF fixes the issue in running analysis when 3DExperience native client does not i.dentify number of cores on a windows machine.
Reference BR: BR10000345387
R2023x_FD01HF 1.2 (Collaborative Designer for X-CAD)2023/02/28
- This HF fixes the assembly save issue with released parts.
R2023x_FD01
HF 1.1 (
3DEXPERIENCE ENOVIA Derived Format Converter Service
2023/02/27
- This HF fixes the Derived Format Converter failure issue.
Reference BR: BR10000340764
R2023x_FD01HF 1.82023/02/22
- With this HF, the distance between two object is well evaluated in the XGenerative Design App
Reference BR: BR10000346990
R2023x_FD01HF 1.1 (3DEXPERIENCE SOLIDWORKS Desktop)2023/02/22-With ths HF, the Mesh creation with BCB mesher is working fine.
R2023x_FD01HF 1.72023/02/21
- This HF fixes the Tool Queries using geometrical attributes in DELMIA Milling Machining App.
Reference BR: BR10000344787
R2023x_FD01HF1.62023/02/16- This HF fixes the performance issue while creating scenario feature for a model with a huge number of loads
R2023x_GAHF0.282023/02/01- With this HF, PLM parameter working issue with DS content has been fixed.
R2023x_GAHF 0.5 (Collaborative Designer for X-CAD)Coming Soon
- This HF fixes the tag application issue on 3D Shape when opened in Assembly Design from Product Finder.
Reference BR: BR10000342965
R2023x_GAHF0.272023/01/23
R2023x_GAHF 0.1 (Collaboration for Microsoft Client )2023/01/16
- With this HF, Drag and drop issue of document in a Project document has been resolved.
Reference BR: BR10000343889
R2023x_GAHF0.262023/01/16
- This HF fixes Interior contour recognition issue on cut.
Reference BR: BR10000344084
R2023x_GAHF 0.252023/01/13
- This HF improves the stability of native apps.
- This HF fixes the synchronization issue of Import links between parts.
Reference BR: BR10000343176
- This HF fixes the virtual bolt errors when running simulation checks in Mechanical Scenario app.
Reference BR: BR10000344388
- This HF fixes the issue where duplicating an analysis case and running a simulation check deletes the results of the original analysis case.
Reference BR: BR10000344098
R2023x_GAHF 0.232023/01/09
> With this HF, Performance degradation issue while using Model creation app has been fixed.
Reference BR : BR10000343434
> With this HF, Issue of simulation staying in "opening simulation" state for a long time before starting compute in case of local non interactive and cloud has been resolved.
Reference BR: BR10000340832
> With this HF, While using SIMULIA physics app execution, number of calls reduced to isUpToDate.
R2023x_GAHF 0.222023/01/05
- This HF fixes Issue where Weld FTA Multi Support loose the FTA link
Reference BR: BR10000341803
R2023x_GAHF 0.212023/01/02- This HF fixes Issue with modified save when Hide-Show is enabled and Issue with checkin when “exact geometry” rule is not defined
R2023x_GAHF 0.4 (Collaborative Designer for X-CAD)2022/12/22- This HF fixes Issue with modified save when Hide-Show is enabled and Issue with checkin when “exact geometry” rule is not defined
R2023x_GAHF 0.202022/12/22
- This HF fixes the crash issue In the 3DEXPERIENCE Fluid scenario creation app, when simulating with manual fluid-solid interaction and surface-to-surface radiation.
Reference BR: BR10000340087
- Bugs with HEATFLOW output are fixed with this HF
R2023x_GAHF 0.3 (Collaborative Designer for X-CAD)2022/12/19
- Assembly and Sub-Assembly with new revision is now synchronized with the cached data when opened.
Reference BR: BR10000340745
- Auto-name is correctly applied to files saved to 3DEXPERIENCE
Reference BR: BR10000342672
R2023x_GAHF 0.192022/12/19
- With this HF, CATIA crash issue after inserting a section on the concept surface with one face mapped has been fixed.
- With this HF, below CATIA issues has been fixed.
>> Inversion of values during Boolean to Real conversions
>> Name attribute no more available on geometrical results
>> Unexpected errors raised by Publish List with literal values
>> Empty value is no more supported on Ratios input of "Split Curve By Ratios" operator
>> Crash during some models opening
R2023x_GAHF 0.182022/12/16- With this HF , Issue of 3DEXPERIENCE frozen after NC code generation has been fixed.
R2023x_GAHF 0.7  (3DEXPERIENCE SOLIDWORKS Desktop)2022/12/16
- With this HF, Native apps launch issue after 23x Golden upgrade (getting an error) has been fixed.
Reference BR: BR10000343001
R2023x_GA
HF 0.17
2022/12/15
- Drafting App crashes while using up and down arrow   BR10000342750
- PDF created from multisheet drawing are viewable  BR10000342857
- No more crash  with specific PPR when trying to open a work cell in a new tab BR10000340956
- Graphical issue by creating geometrical tolerances is fixed. BR10000322357
- After a crash of the 3DEXPERIENCE, 3DSWebHelper sub process are orphan and starts draining your CPU resources. BR10000342057
R2023x_GAHF 0.162022/12/09
- crash when opening Connection Manager on a specific data has been fixed.
- Issue of mini dump while updating a line fastener has been fixed.
- Virtual Bolt update is KO on a specific data has been fixed.
- Virtual Bolt Detection cancel takes huge amount of time has been fixed.
- Session gets close and crash while doing Global update after creating the Virtual Bolt has been fixed.
- Transparent body with thickness remains visible after using Interference command has been fixed.
- Session crash while doing penetration checks with “All meshes” option has been fixed.
- Direction of arrow isn't the same for explicit and implicit model has been fixed.
Reference BR: BR10000341258 / BR10000342196
R2023x_GA
HF 0.2 (
2022/12/09
- This HF fixes the app launch issue with error "An unexpected error has occurred while performing authentication - please contact your administrator / communication traces may be required." when Internet Explorer 11 (iexplore.exe) is not available on the workstation.
R2023x_GAHF 0.152022/12/06
- This HF fixes the Native app launch issue with error "An unexpected error has occurred while performing authentication - please contact your administrator / communication traces may be required." when Internet Explorer 11 (iexplore.exe) is not available on the workstation.
R2023x_GAHF 0.6  (3DEXPERIENCE SOLIDWORKS Desktop)2022/12/06
- With this HF, Auto-naming issue of files saved to 3DEXPERIENCE has been fixed.
R2023x_GAHF 0.142022/12/05- With this HF, Performance issue while switching app between mechanical scenario app to structural model app has been fixed.
R2023x_GAHF 0.132022/11/29- Issue while Importing 3Reference BR: BR10000340151DXML As Reference with re-identification of an object type "catalog chapter DS" coming from 2013XE has been fixed through this HF.
R2023x_GAHF 0.122022/11/25
- This HF fixes the effectivity filtering issue.
Reference BR: BR10000339945
- This HF fixes empty compass issue in Native apps. Also, it has fixes to improve platform performance.
R2023x_GAHF 0.5  (3DEXPERIENCE SOLIDWORKS Desktop)2022/11/23- With this HF, Issue of NO SOLIDWORKS preview on saving part file has been resolved.
R2023x_GA
HF 0.1 (
2022/11/20- This HF fixes the save issue with Chinese OS on SOLIDWORKS Connector.
R2023x_GAHF 0.4  (3DEXPERIENCE SOLIDWORKS Desktop)2022/11/20- This HF fixes the save issue with Chinese OS on SOLIDWORKS Connected.
3DEXPERIENCE Launcher VersionPublication DateAvailabilityContent
24.23.427
(optional)
2024/07/06All usersNew version of the 3DEXPERIENCE Launcher for R2024x FD03 level:
- General Improvements
- Renewal of the dslauncher.3ds.com ssl certificate
23.50.857 (optional)2024/02/10All usersNew version of the 3DEXPERIENCE Launcher for R2024x FD01 level:
- Bugfix: embed a new version of the Hub to fix a problem with ZTNA
23.35.5122 (Optional)2023/11/20All usersNew version of the 3DEXPERIENCE Launcher for R2024x GA level:
- Solve 3DEXPERIENCE Launcher update issue for users who already has a sectigo certificate in the intermediate store.
Reference BR: BR10000364786
23.35.4851 (Optional)2023/11/04All usersNew version of the 3DEXPERIENCE Launcher for R2024x GA level:
23.14.3628 (Optional)2023/07/08All users- New version of the 3DEXPERIENCE Launcher for R2023x FD03 level
22.48.543 (Optional)2022/12/08All users- General improvements
- Solve installation issue for users with a whitespace in the username.
Reference BR: BR10000342551
- Customers using Sentinel One antivirus should pay attention to this article QA00000103253 and contact their IT to make sure the 3DEXPERIENCE Launcher (3DEXPERIENCELauncherGUI.exe and 3DEXPERIENCELauncherBackbone.exe) is part of the exception list.
