User Groups in Triggers
You can now specify a user and/or a user group in the "Who" field for a 3DSwym trigger.
You can search for a specific user group using a search command, or start entering the name to see choices the same way you already do for users.
IP Classify and Reuse as Action Ingredient
IP Classify and Reuse is available as an action ingredient which allows to automatically classify objects.
The two actions are:
- Classify content with definition purpose adds an item to a definition class.
- Classify content with categorization purpose adds an item to a categorization class.
Adding Multiple Users
You can add multiple users for some actions in:
- Project Planning: for the Assign managers to Project and Assign users.actions.
- Change Management: for the Assign users action.
- Issue Management: for the Add members action.
Table Content for Ideas, Questions and Wiki Events
Rich text table support is expanded to include 3DSwym content for Ideas, Questions, and Wiki events.
In addition, table variables are available for fields @user and @date predicates. To specify these, for the user field, use the @ tag in the 3DSwym content. For date fields, you must enter dates in the format "dd/MM/yyyy". For example, "25/05/2025".
Changing the Platform
You can change the platform in the Preferences.
In a multi-platform environment, if you are assigned different roles depending on the platform, the ingredients loaded can be different. This enhancement allows you to change to another platform within Potion Lab to see different ingredients.
Shared/Transferred Potions
A 3DNotification is sent to the owner of a shared potion when his/her potion is activated or deactivated.
When transferring the ownership of a potion a 3DNotification is sent to the new owner.
Issue Management
The Issue Management ingredient has a new action to update issue maturity.
