Ask your questions or find more information on ENOVIA products on the ENOVIA user community
Enhanced app: PLM Collaboration Services for CATIA V5
Obsolescence indicator
Save time by dynamically checking for obsolescence before saving to 3DEXPERIENCE
Save is blocked when design model has changed in the platform
Change can occur from Web or save from other CATIA V5 users
- Save will detect Delete, Add or Modify
3DEXPERIENCE CATIA Changes will also be detected when saving from CATIA V5
Replace by Revision now uses Version History widget
Improved User Experience with Replace by Revision consistency between Web and Win
Replace by Revision will now leverage the Lifecycle capabilities as used in the web
- Version Graph
An existing design can be replaced with a different revision only if they contain files with different names
Enhanced app: PLM Collaboration Services for SOLIDWORKS
Improved Duplicate Command in the Collaborative Lifecycle Widget
Improved User Productivity with Simplified Reuse of Existing Designs
- The Duplicate command will now allow duplication of parts and assemblies containing multiple configurations
- Only the visible configuration structure is duplicated
- The Duplicate command will retain the original file names and apply text transformations (prefix, suffix, replace) rather than generating names automatically using a number
Ability to set the engineering item part number from CAD
Improved User Experience by collaborating on the product structure directly from the authoring tool
Enhanced app: PLM Collaboration Services for Inventor
Advanced CAD features support
Improve User Experience and adoption with support of advanced CAD features
Support of Derived Components
- Parts and Assemblies are supported
- Modifications s of the Base component are automatically reflected in the derived component
Support of Presentations
- New data type support
- Save, Open and Revise
Enhanced app: PLM Collaboration Services for AutoCAD
Neutral format available for post processing of drawings
Improved usability for drawing visualization and validation
Visualize drawings in 3DEXPERIENCE through SVG formatted files
Enhanced app: PLM Collaboration Services for Altium Designer
Access data through a central widget embedded in Altium Designer
Improved user experience and ease of use
- One Central 3DSearch Widget to access Altium related data
- Context sensitive actions to
- Open/modify…
- Place/Insert …data from 3DEXPERIENCE in the ECAD Application
Replace a local revision with a different revision available in 3DEXPERIENCE
Improved User experience and flexibility
- Visualize existing revisions of the selected ECAD document available in 3DEXPERIENCE directly in the ECAD application
- Replace a local revision in ECAD by a different revision available in 3DEXPERIENCE through the complete hierarchy (e.g. hierarchical schematics)
Enhanced app: ENOVIA Engineering Release
Definition of the Part Number through a Formula
Improve productivity with intelligent part numbering
- Administrators now can define a formula for the Part number in the “Collaborative Space Configuration Center”
- This formula is used by the “Set Part Number” function when generating the part number
- This formula is based on a combination of the following syntax with any order:
- Text
- Attribute
- User Input
- Counter
Limitations
- Same formula applies to all Engineering Items
Definition of continuous quantities of materials
Improved Productivity and User Experience for defining continuous quantities in volume
You can now define the list of “Engineering material” for an engineering item by:
- Selecting an existing material (of type “Core material”)
- Define the Quantity and the Unit of measure (*)
Examples of such material:
- Glue, Oil, Petrol
“Engineering material” is the same object used also for the model based engineering (3DEXPERIENCE CATIA and Simulation).
When using the “Group by Reference”, user gets the total quantity of each engineering material per each reference.
(*) Limitations
- Unit of measure is now limited to “Volume” (Liter, m3 etc…).
Enhanced app: ENOVIA Product Structure Editor
Support of Rejecting variant values / Options during Effectivity Definition
Enhanced Flexibility and Productivity during the Effectivity definition
What
- During the effectivity definition of engineering items (variant/option group) , user can now reject certain values/options from the list instead of selecting many others
- This will eliminate the value from the effectivity definition and will be considered as “NOT” in the effectivity expression
How
- Available on right mouse button (RMB) for effectivity edit, and selection of “Reject”
- This selection means: All other options are valid except of the one rejected
Why
- This will reduce the length of the expression text
- New values/options added in the future will also be valid for this instance without the need to redefine the effectivity
This highlight is available in the widgets which enable effectivity update such as:
- Product Structure Editor
- Engineering Release
Expose and edit attribute rage values from within the Tree List view
Improved User Experience with drop down list view and select
- Attributes that have a range of values assigned will now be shown in the Tree List view through a drop down list
- Values are editable if set that way by admin
3D Positions can now be copied and pasted to other items
Save time with quick and accurate 3D Position copy
- During mockup, it can be convenient to copy 3D locations into other items within another structure for positioning purposes
- The new positioning is then reflected in both the structure and the associated 3D model
Enhanced app: ENOVIA Relational Explorer
Relational Explorer support for Design Review and Interference simulations
Easy navigation on Design Review and Interference relations
"Relational Explorer" supports now the following types of objects:
- Design Reviews
- Design Review Highlights
- Interference Simulations
- Interference Metrics
All these relations are available in the "profile":
- "Review and Interference Relations" (under the “Customized Relations” of the Relation Explorer)
Enhanced app: ENOVIA Project Management
Calculate Float values
Improve planning quality assessment
Total Float and Free Float are displayed in the Structured View (Planning view) and in the Flattened view
Enhanced app: ENOVIA Project Planning
Project List filters
Improve User Experience with project filtering
My Projects filter restricts the list of projects to the ones user owns and the ones where the user is set as Project Manager
3DDrive as default repository
User can search a 3DDrive or Drag one to define a default repository that is used when uploading documents
Enhanced app: ENOVIA Route Management
Route Task Management leveraging 3DEXPERIENCE User Groups
Improve productivity by assigning groups of people to route tasks
- User can now assign 3DEXPERIENCE User Groups to Tasks
- When a User Group is assigned to a task the User Group will be added as members to the route
Enhanced app: ENOVIA Bookmark Editor
Subscriptions from Bookmark Editor and Mobile Readiness
Improved user experience with enhanced subscription experience
User can now subscribe to Item changes from Bookmark Editor
Note: Bookmark Editor App is now Mobile Ready
Enhanced app: ENOVIA Issue Management
Issue Management based on validation process
Save time with automated issue validation process
An Out-Of-The-Box validation process is provided to validate the change and action performed on an Issue.
- Approve or Reject issue before Active and Closed maturity state
- Automatically change the maturity state on approval or rejection
Mobile support
- iOS
- Android
Enhanced app: Collaboration for Microsoft
Enhanced integration with Microsoft Office
Improved user experience with enhanced Collaboration for Microsoft Capabilities
Ability to support bi-directional sync of Meetings between 3DEXPERIENCE and MS Outlook integration
- The MS Outlook ribbon will provide a single button to synchronize assigned and owned meeting from 3DEXPERIENCE to MS Outlook.
UX consistency for document management in Windows Explorer integration and support for custom attributes
- Create a simple and intuitive user experience when working with documents and folders.
- Additionally, this enhancement aims to provide a consistent user experience across the integration for similar operation.
- 3DEXPERIENCE Save context menu on local files and folders
- Drag and drop of local files and folder to 3DEXPERIENCE
- Context menu and ribbon button in explorer integration
- Support custom attributes at creation
Enhanced app: ENOVIA Connected software
Collaborate on Federated Software Content
Improve collaboration with ability to review software code on platform and modify same code in a local workspace
Pull software content for development in local workspace using exposed full repository path URL for software item version
- Review software code on platform and modify same code in local workspace.
Data visibility and confidence, exposed external SCM commit version.
- Know exactly what version of the software code being reviewed and referenced in 3DEXPERIENCE, using exposed external SCM commit version.
Download SCM connector from Cloud
Improve User Experience with SCM connector download from cloud
- Eliminate need to separately download local SCM connector from off-cloud download site.
Enhanced app: ENOVIA Requirements
Edit requirements and comments titles from the specification editor
Edit requirements and comments titles from the editor.
Enhanced app: ENOVIA Copy & Artwork Management
Artwork Element Revision Management
Improve productivity by enabling artwork experts and copy authors to work concurrently on multiple revisions of copy content
- Ability for an user to choose the current latest revision or the existing released revision of the copy content on a POA, depending on the need of the artwork
- Automation to ensure that a POA or a Copy List that is “In-work” always uses the latest revision but with an override for the user to update to a chosen revision
- Clear visual indication to a user when the latest revisions of copy content is not used on the POA
- Warnings to the user during POA promotion indicating that a latest revision is not being used
Create or re-use right content on a POA, visualizing the copy on the artwork directly from within the Artwork Connector
Improved User Visualization Experience
- Manage the right content on a POA including creating or re-using artwork elements and translations using the POA Edit capability from within the Artwork Connector
- Ability to perform search and add existing of copy content from across the platform without being constrained by the product hierarchy of the POA
- Re use existing elements with similar content on the POA from both the web app and in the Artwork Connector from within Adobe Illustrator
Artwork Management Improvements
Time saving enhancements for artwork management allowing graphic designers to focus on artwork rather than assembly of the copy on artwork
Improved Marker Management on Multi Map Screen
- When a user constructs the mutli-map by selecting copy elements from the artwork assembly panel or the multi-map panel the order of selection is saved and used.
- This ensures that a user spends less time ordering the elements after addition to the multi map
- A new column indicating the exact numeric position is also provided on the multi-map view
Filtering on Structured Copy
- Filtering on structured element displays both the parent and the child of that structure to provide the right context for a user
Enhanced app: ENOVIA IP Classification
New interface to create classification attributes by ‘Leader’s
Enhanced business process support / Cloud adoption
Why:
- Today, customers are forced to use a set of predefined attributes for classification purposes (Indexation of these attributes must be done manually)
What:
- A new tool allows customers to create their own attributes and have them available for automatic indexation process (*)
This tool is available:
- On cloud and on premise
- For users who have access level of “leader”
(*) after creating all the attributes, they must be deployed using the Indexation command available in Collaborative Spaces Control app
New app: ENOVIA IP Classify and Reuse
New Widget “IP Classify & Reuse”
Quickly identify, navigate and reuse valuable IP
A new widget is now introduced in this release for:
- Data classification into the appropriate location with the defined taxonomy
- Enterprise Classification structures navigation
- IP search using classification attributes
Attribute list can be personalized
Enhanced app: Parametrization Console
Activate/deactivate the generation of derived format (XVL) when an object is promoted to a frozen state
Improved flexibility when generating derived format
- Derived Format Management is available from a list of parameterization domains
- When “Generate XVL file” is unchecked, it deactivates the generation of derived format (XVL) when an object promoted to a frozen state.
- When “Generate XVL file” is checked, it activates the generation of derived format (XVL) when an object promoted to a frozen state.
Enhanced app: Engineering Adapter for X-PDM
XPDM Export in BatchServer mode
Save time and improve user experience by providing a background export option
- Transferring PLM data available in XPDMXML to 3DEXPERIENCE platform using XPDMImportExportBatch from the batch monitor.
- Export options allow user to include or exclude:
- X-PDM Owned Objects
- Documents: images, text, etc.
- Files, Visualization data
- Only modified
