Ask your questions or find more information on DELMIA products on the DELMIA user community
Enhanced App: DELMIA Work Instructions
You can now create 3D-Arrow-Markers based on Pointed Element
Improvements in the process of defining 3D-Arrow-Markers.
- Perpendicular to Planar Surface
- Normal to Curved/Revolution Surfaces
- Snapping to Axial direction for revolution surfaces and circles (using SHIFT toggle)
Improve manipulation of 3D-Arrow-marker ( with first-point, last-point and direction-axis)
Enhanced App: DELMIA Additive Part Preparation and DELMIA Powder Bed Fabrication
Additive apps have been improved and are now easier to use
- There is now an optional visual help for build envelop, recoater and gas flow direction
- Information button to explain the parameters. They are available for all the commands
- Rules management command always accessible in the app
- Progress bar when using external services from Machine builder
- Simulation libraries directly stored in the machine for preselection in Distortion Checker app
Enhanced app: DELMIA Work Plan Publication
It is now allowed to perform multiple operations for PND Export
This function allows multiple operation maturities to be defined for PND Export to Apriso.
- Prior to this change all operations had to be at the same maturity
- Now export is allowed as long as all operation maturities match any designated maturity
- Simplified and less restrictive PND Export process
- Requested by Airbus
