Offers an improved end-user experience while defining the Manufacturing/Service BOM and Processes to access relevant information. Define and analyze complex, configured, and non-configured manufacturing data structures with new, efficient tools.
• New BI easily identifies, through color-coded maturity states, both consumed and defined objects
• A new structure visualization mode within the PPR spreadsheet editor – Flat View, allows the user re-organize the original structure and dynamically creates it based on any grouping criteria (reference, attribute value or object type)
• Simplify overall user experience when defining and reviewing configured processes
o Automatically filter Operations based on consumed manufacturing items (implicit filtering)
o Maintain the process sequence after filtering out Operations
o Implicit filtering helps to avoid defining or replicating variants or options effectivity from Manufacturing Items to Operations
New BI Design State for all Manufacturing Items By activating the BI, all relevant Manufacturing Objects for the current Application are colored according their Maturity state (Private, In Work, Frozen, Released or Obsolete here) In Planning Structure application, Product, Manufacturing Items, Workplans/General Systems, Operations and Resources are colored in both tree and 3D
New 'Flat View" command in the PPR Spreadsheet editor You can toggle from standard multi-level view to flat view, with all instances at the same level, and reverse
New filtering capability to implicitly filter your Process data (Operations) based on filtered Manufacturing Items structure A new option allows filtering all siblings Operations without any consumed Manufacturing Item, within a sequence of filtered-out Operations. In the Filter PPR Content when ‘Implicit filter’ option is checked, as soon as a filter is applied to the Manufacturing Items structure, the Process structure will be filtered as well implicitly.
