[DELMIA] Manufacturing Engineer for Marine
Offers an improved end-user experience while defining the Manufacturing/Service BOM and Processes to access relevant information. Define and analyze complex, configured, and non-configured manufacturing data structures with new, efficient tools.
• New BI easily identifies, through color-coded maturity states, both consumed and defined objects
• A new structure visualization mode within the PPR spreadsheet editor – Flat View, allows the user re-organize the original structure and dynamically creates it based on any grouping criteria (reference, attribute value or object type)
• Simplify overall user experience when defining and reviewing configured processes
o Automatically filter Operations based on consumed manufacturing items (implicit filtering)
o Maintain the process sequence after filtering out Operations
o Implicit filtering helps to avoid defining or replicating variants or options effectivity from Manufacturing Items to Operations
I
New BI Design State for all Manufacturing Items
I
By activating the BI, all relevant Manufacturing Objects for the current Application are colored according their Maturity state (Private, In Work, Frozen, Released or Obsolete here)
I
In Planning Structure application, Product, Manufacturing Items, Workplans/General Systems, Operations and Resources are colored in both tree and 3D
I
New 'Flat View" command in the PPR Spreadsheet editor
I
You can toggle from standard multi-level view to flat view, with all instances at the same level, and reverse
I
New filtering capability to implicitly filter your Process data (Operations) based on filtered Manufacturing Items structure
I
A new option allows filtering all siblings Operations without any consumed Manufacturing Item, within a sequence of filtered-out Operations.
I
In the Filter PPR Content when ‘Implicit filter’ option is checked, as soon as a filter is applied to the Manufacturing Items structure, the Process structure will be filtered as well implicitly.
