Forward content
Today we are very happy to present you the Forward content functionality that can duplicate a content from a community to another.
The new Forward functionality offers a new way to forward some contents from community or conversation to another community or conversation so that broader audiences can be reached while still keeping their scope and subject. The forward can only be done from one content to one destination.
The different content types that can be forwarded are:
- Posts
- Media (image, video, GIF, Document)
- Questions
- Ideas
- Messages
- Conversation
What cannot be forwarded:
- WeDo
- Surveys
- Wikis
- 3DStories
- 3DSketchs
What is not kept when forwarding:
- views
- likes
- comments
- Idea Status
- Media if you are not the author of this Media and if you are not owner of the source community
Who can forward content?
- Community owners
- Content owners
- Members of a conversation
(As community owner, when forwarding someone else's content, the newly created content in the destination community will show whom it has been "forwarded from". Even if it is forwarded again by another person, the original author is always kept, unless the content is edited. If you are the author of the forwarded content, there won't be any "Forwarded from..." mention."
Conversations
- When you start a new conversation, as soon as you add someone to the conversation, recent conversation(s) you had with this person will be listed in case you'd like to reuse one of the existing ones.
- The above feature is also valid, when starting a group conversation.
- If you attempt to create a new one-to-one conversation with someone you already have a one-to-one conversation, the existing conversation will be reused and opened.
- If you attempt to create a new group conversation with the same persons of an already existing conversation, the existing conversation will be suggested (see 2nd bullet point above), but can also decide to create another one. Tip: Make sure to set a topic to differentiate the two conversations.
- If you add new members to an existing one-to-one conversation, a new group conversation will be created.
- If you add new members to an existing group conversation, they will be added to that conversation and will see the conversation history.
Story integration in 3DSwym
- When adding a media in a community, you now have the option to create a Story.
3DDashboard
Manage Dashboards enhancements
The Manage Dashboards modal continues to evolve, here are the new capabilities:
- In addition to the known Tiles view, a new List view is now available
- Only from the Tiles view, dashboards can now be easily moved using drag and drop functionality from All dashboard, My Favorites and Recycle bin
Better grid layout management from mobile
The Grid layout (the default tab layout) is now more mobile friendly. Until now when you create a dashboard on mobile and then open it on a desktop, the result was weird (everything on 1 column even on desktop).
A new algorithm has been applied to try to fit better.
Multi-tenant widgets
When drag and dropping a widget without pre-selecting the widget tenant, instead of getting an error, now there is a modal that prompts you to select from which tenant you’d like to load the widget. Let's see how it looks through the following video.
3DDrive
Within the Shared with me section, you can now directly remove your access to the shared content by simply clicking on the menu of the folder and select the Remove access command. This command is only available if a folder is shared to you directly. If a folder is shared to you by User Groups, the command is not available.
Other new features:
- 3DDrive now supports CityGML files along with their textures. This includes the actions already supported by file intelligence i.e Preview in 3DPlay, Download, Move, Copy, Put in trash
- 3DEXPERIENCE Drive native App will now use Windows Notification center to dispatch notifications regarding events like quotas exhaustion, or files locked preventing synchronization
- When switching back to a previously synched Drive from another tenant, 3DEXPERIENCE Drive native App will offer the possibility to reuse the corresponding local synched folder.
3DSearch and 6WTagger
UQL for 3DSwym
If you are using UQL to make searches on Swym content, you can now include tag filtering directly in the query. Let's say you want to search for all the ideas of the Play 3DEXPERIENCE! community with the maturity status "New Enhancement", the corresponding 3DSearch query is:
[ds6w:type]:"swym:idea" AND [ds6w:community]:"Play 3DEXPERIENCE!" AND [ds6w:status]:"New Enhancement"
Now let's say you want to have the results directly filtered on the User Tags 3DDrive and To be reviewed using the UQL query. Since R2021x FD04 it is now possible and here is the example:
[ds6w:type]:"swym:idea" AND [ds6w:community]:"Play 3DEXPERIENCE!" AND [ds6w:status]:"New Enhancement" AND [ds6w:what]:"3DDrive" AND [ds6w:how]:"To be reviewed"
Multi-Tag selection action redesign
If you didn't already know this, it is possible to filter search results simultaneously using several tags. To do so, before R2021x FD04, once you had your search results and the tagger filled, you needed to press the Ctrl key and select several tags, for example Tag1 and Tag2. Once the Ctrl key was released the search results would be refined on Tag1 OR Tag2.
While this capability is still available in R2021x FD04, a specific command is now available in the 6WTags panel.
3DPlay
Large Data Visualization
Data support: Published Experience Media
Data support: CityGML with multiple files
Data support: 3DWhiteboard content
PDF: Text selection & copy
Rich Client app VR: minimal navigation
Improved navigation abilities in VR for HTC Vive in the 3DEXPERIENCE Rich Client app
- It is possible to “grab the scene” to move it, even when using other commands like measure, section, etc
Data support: TXT files
Print Real Size
DXF/DWG elements (Civil3D data)
- The scope of supported elements in the DXF & DWG formats has been improved
- DXF & DWG files authored in Civil3D, now display a message warning that they are only partially supported
Markup visualization for PDF in 3DSpace
3DSketch
- Create 3DBriefs from multiple pictures
This new feature allows you to position one picture per plan. It becomes easier to create a precise 3D sketch at the right scale.
Step 1 - Insert images on plan
Step 2 - Sketch on images
- Step 3 - Refine your 3DBrief
- 3DSketch copilot becomes zoom independent and more permissive
Shape recognition assistant has been improved on this release: the algorithm is now able to detect precisely the shapes even with small or large scale factors.
- Eraser size is sensitive to the finger / pencil acceleration
Slow / Normal gesture
Fast gesture
- Publish panel simplification for 3DSwym
Sketch publication has been harmonized with others 3DSwym media. Just give a title to your sketch and share it on your favorite community or conversation!- While publishing a sketch in 3DSwym What's New you will have to specify in which community the sketch needs to be published, you no longer have to do it when creating the sketch directly from your community feed.
- 3DSketch application gets closed after publish.
- Confirmation panel is popped when application is closed without publication.
3DStory
- As indicated above, the Create command is now available directly from 3DSwym.
- There is a new UI panels available in the left vertical menu bar that includes most of the commands to improve the editing workflow.
- When creating a Story with multiple scenes, you can now add transition presets between them.
- Preview Selector is now available from the 3DStory publish panel so that you can choose the scene you want to use as the story preview.
