[3DEXPERIENCE Platform] Collaborative Business Innovator + Collaborative Industry Innovator
3DDashboard
Add new widget actions on topbar
  • “Add Widget” option
    ✓ Ability to open the 3DCompass when you try to Add widget from topbar
    ✓ If 3DCompass is already open, Message “Drag and drop widget from 3DCompass (left panel) into your dashboard.” will be displayed.
Note : This item menu will only be available on editable dashboard (owner dashboard)
  • “Share Widget” option
    ✓ Ability to open the share widget box when you click on the 'Share widget' option from the topbar
Note: Only the focused widget is the shared widget. If no focused widget, the item menu is disabled (fade-grey)
This item will only be available on the dashboard where the user is able to share widgets.
Dashboards & cockpits lists
As already available and as you know the Compass is the gateway to all what you need to accomplish your job and gives you access to:
  • My Roles section reveals the roles granted to you. Click on a Role to see the related Apps and to discover its values. Role icons reveal the related Brand, for a quick identification of their field of activity.
  • My Favorite Apps
  • My Apps section shows all the apps you have access to.
  • My Cockpits section gives you access to dashboards provided by commercial roles to help you experience what the role has to offer.
New with R2022x FD04, as the experiences available in My Cockpits section are in the form of dashboards, it was natural to also have this section in the “Dashboard List” now renamed “Dashboards and cockpits list”.
When you open the “Dashboards and cockpits list”, you will still find in the following order the:
  • My Favorites section that list you favorite cockpits or dashboards.
  • My Cockpits section that will list, for now, the dashboards provided by commercial roles, including the Platform Management dashboards.
  • My Dashboards section that lists all your dashboards.
On the Manage dashboard, all 'dashboard' and 'cockpits' will be visible in the 'All' view, New filter with the name Cockpit is added in the filter section.
Create community tags from the community settings UI and display that below the community header
Community Tags enable community members to organize community content using a common set of relevant tags that can be suggested and applied by a simple click, eliminating spelling inconsistencies and easier content filtering.
  • Create a Community Tag (in Community preferences)
  • Filter by Community Tag
  • Tag a new content based on community tags suggestion
3DDrive
  • New sorting attributes
"Size", "Type" and "Creator" attributes are now sortable. You can use the sort menu and the list view columns to sort on these new attributes.
  • New "Get link" action
We have added a new "Get link" action which is a shortcut to "Share" > "Share by link" > "Copy link". This action is available in the action bar based on your content selection and in the item actions menu.
  • Computed thumbnails for Office documents
A thumbnail is now generated for Office documents when the file is uploaded or updated. The thumbnail generation may take some time before you can view it.
  • Support preview of STPX and STPXZ formats
STPX and STPXZ formats are now supported in 3DPlay through 3DDrive.
Changes
  • Improve Drives panel resizing and add support for touch devices
The icon for resizing the drives panel now only displays if the user hovers the mouse over the resizable area. To resize, you can use the entire vertical area. Also, touch devices are now supported.
3DWhiteboard
3DWhiteboard Homepage
  • 3DWhiteboard widget app has now an homepage to simplify access to your whiteboard content published in 3DSWYM. In a longer term, more features such as guided tour, what’s new, my recent content and my drafts will be available.
Since R2022x FD04, you can:
  1. Create a new Whiteboard                                         ​​​​
  2. Display all 3DWhiteboards published by the user
  • Clicking on a Whiteboard will open it in editing mode:​​​​​​​
  • To go back to Homepage, you can click on « home » button in the top right corner. Your current content will be saved:
Sticky notes
Sticky notes are now available in 3DWhiteboard to simply write down ideas, comments and suggestions.
Texts and links
The experience of creating and editing texts has been improved. You can directly double-click to edit or copy/paste texts in 3DWhiteboard.
Combined with better link detection and preview generation, you can express and illustrate your concepts more easily.
3DSketch
3DSketch Homepage
  • 3DSketch widget app has now an homepage to simplify access to your sketch content published in 3DSWYM. In a longer term, more features such as guided tour, what’s new, my recent content and my drafts will be available
  1. Create a new Sketch                                          ​​​​​​​
  2. Display all 3DSketches published by the user   ​​​​​​​
  • Clicking on a Sketch will open it in editing mode:​​​​​​​
  • To go back to Homepage, you can click on « home » button in the top right corner. Your current content will be saved.
3DPlay
3DPlay for all
Make 3DPlay the application which adapt to all platform users
Drag and drop from desktop
To deliver an unified experience to user, UI for upload progress bar is now homogeneous with 3DPlay standards.
Visualization experience
Advanced navigation experience with an improved visualization
Substance materials
Advanced navigation experience with a realistic visualization supporting the display of substance materials.
important notice:
Substance materials are only supported in web from R2022x GA:
  • Substance materials created with R2022x GA are supported but they must be edited using R2022x FD01 Rich Client in order to be compatible for web,
  • Substance materials created or updated from R2022x FD01 are compatible for web “out of the box”.
Discover 3D models
Intuitive navigation experience to discover 3D models
New explode
UI for the explode command evolves to be more modern and more intuitive for user.
3DPlay universal player
A single player for all types of media
Supported formats
Enrich the list of supported formats to make 3DPlay the application essential to read any content.
Performances
A navigation experience with best performances
XCAD files in 3DDrive
Loading times for XCAD files hosted by 3DDrive are improved to deliver an experience to user always more powerful.
3DStory
Here is the summary of the new features;
  • Story status: Story status (unsaved, draft, publish) is now explicitly displayed within the app inside Scene View and Publish Panel.
  • Images highlight: Images with hyperlinks are now easier to discover at play: they are highlighted at mouse hover.
  • Home Page display performances: Recent and Public stories now display faster from Home Page.
3DSearch and 6WTags
You are now able to visualize information related to a selected object thanks to 6W Information Icon
Information option available
You can now decide which tag to colorize and un-colorize in the 6WTag panel:
