Collaborative Business Innovator
WeDos and Project Planning
You now have the possibility to add WeDos to a project in ENOVIA Project Planning.
When a Wedo has been added to a project in Project Planning, the project name is displayed in the details of the WeDo.
If you modify a WeDo task properties, those changes are reflected in the summary charts of the Project Planning app.
Content, Community Creation and Conversation Engagement
- A new welcome message is now displayed when you access 3DSwym for the first time. If you use a desktop or a tablet, the message is displayed in the What's New feed in the middle pane. The message is displayed in the left pane if you use a mobile device.
- For mobile devices you can now:
- In the "Communities" tab, create new community content by clicking 'Publish Content' and if your administrator has enabled it create a new community by clicking 'Create community'.
- In the "Conversations" tab, start a new conversation by clicking Start conversation.
- Select the "Thanks, I got it" check-box to hide the message, and the quick creation commands listed above.
- You can now request or create a community from the left pane.
3DDashboard
Display Platform (tenant) and 3DSpace credentials information inside widget header
The platform information and 3DSpace credential information will be displayed inside the widget header, if the following conditions are met:
- The widget must be tenant aware and the user must be invited on more than one tenant
- The widget must be Collaborative Space and Credentials aware, even if the user is invited to only one tenant
If the conditions are met, the widget will display a new cloud icon in the header. When hovering this cloud icon, the tenant and/or Collaborative Space/Credentials information will be displayed.
Additionally, for stand-alone apps, tenant and credential information are available with the possibility to change them. Below is an example with Project Management.
3DNotification Center
Archived Notification Filtering
You can now filter your notifications by adding those which have been filtered. Notifications older than 90 days are archived.
User Profile Access
In 3DNotification Center, you can now access a user's profile by clicking the user's picture displayed along with a notification.
3DSearch and 6WTags
Instant Search Enhancements
The Instant Search feature can now display a People category and let you open a user's profile in 3DSwym.
3DPlay
Side Panel Display of Information
You can now display a tabbed side panel that reorganizes simulation information and provides access to social comments about your results. This side panel replaces the Information Panel of previous releases and provides access to data from the following tabs:
- You can use the Physics Simulation tab to do the following:
- Display content that was in the information panel of earlier releases, including charts.
- Extract, minimize, dock or stack charts in the viewer.
- You can use the Relations tab to do the following:
- For physics simulations, list the objects related to the loaded asset, such as simulated products and the finite element models used.
- For finite element models, list the objects related to the associated product structure and shape, and physics simulations that are used.
- You can use the Properties tab to display PLM attributes or metadata of the current physics simulation or finite element model.
- You can use the Social Comments tab to add comments and reply to comments associated with the physics simulation or finite element model. These comments are shared across the 3DEXPERIENCE platform in search results, 3DSpace, and other apps that access 3DSpace data and integrate comments.
Benefits: The side panel offers easy navigation and access to information on PLM attributes and simulation experience content information. In addition, the side panel facilitates sharing by providing a place to create comments and provide feedback on the Physics simulation or finite element model that you load.
Support of 3DM, DGN, FBX, and ZAE files
You can now open documents of the 3DM, DGN, FBX, and ZAE format in 3DPlay.
Action Bar Optimization for Tablets
The optimization of the action bar for using 3DPlay for Dashboard on tablets is taken a step further.
3DSketch
You can now create advanced and precise sketches with the new shape intersection algorithm.
- Intersections with the shape itself
- Intersections in 3D (different plans)
3DStory
Here are the new features about 3DStory:
- Recent stories are now directly available from 3DStory Home Page. They can be edited, saved, or “saved as new” allowing users to reuse previous stories.
- Timeline control is now available for videos. It is also possible to trim your video directly from 3DStory
- A progress bar is now displayed in slideshow mode
Collaborative Industry Innovator
A video says it all, so let's discover some highlights for Collaborative Industry Innovator apps in R2021x FD07!
Bookmark Editor
Find in Tree Command
You can now search a bookmark inside a tree structure and expand the structure to a specific bookmark using the Find in tree command from the left pane.
Upload Folder and Preview Command
You can upload a folder from your computer to the Bookmark Editor app using the Upload Folder command from the action bar.
Note: Be aware of the current limitations concerning the upload option, number of folders is 125 and number of files is 250.
You can also opt to display the preview of a document from the context menu.
Derived Outputs Naming Conventions
Naming conventions of the derived outputs that are downloaded from the Derived Outputs side panel are updated.
Collaborative Tasks
Edit Documents from a Task
You can edit documents created from a collaborative spaces source as attachments or deliverables.
Benefits: You can edit documents from collaborative spaces directly from a task or the context.
Cross-Widget Highlighting of 3D Product Task Deliverables in 3DNavigate
A task having deliverables related to a 3D product can be loaded in 3DNavigate where the deliverable parts are highlighted and focused in 3DNavigate. These include deliverables on tasks from Collaborative Tasks, Project Planning, Project Management, WeDo, and standalone.
Benefits: Task deliverables for a 3D product from Collaborative Tasks are highlighted and focused in 3DNavigate.
Issue Supported in Context
You can specify an issue as the context for tasks.
Benefits: You can set the context to an issue and associate tasks to it.
Issue Management
Estimated and Resolution Dates
Issue Management now leaves the Estimated Start Date, Estimated End Date, and Resolution Date fields blank when you create an issue. These fields should be filled in based on the specific circumstances and not based on the creation date of the issue.
In addition, the Resolution Date, Action Taken, and Resolution Statement fields must be completed before you can promote the issue to the Completed state.
Context Menu for Issues, Attachments, and Related Objects
The context menus for issues and related objects includes several label and icon changes to better indicate what actions the options perform.
Information for Attachments and Related Objects
The context menus for attachments and related objects now includes an Information command that opens a window with properties and additional information about the object.
Route Management
Creating Routes
You can now create a route with only a name. The Name field is now the only required field when creating a route. You can add additional details whenever you have them available.
Mobile Devices
You can now use Route Management on mobile devices.
Route Templates
Users with the Leader access role can create and manage route templates.
Home Page
You can now use the home page to quickly list your routes and route templates, and create new routes and route templates.
