3DDashboard
Resizable Left & Right Panels
You can now freely resize the Left and Right panels to fit your workflow, instead of relying on a single fixed width. This covers in particular:
  • Drag-to-resize: Grab the edge of the Compass, Tagger, Notification Center, 3DSwym, Communities & Conversations, or other side panels and drag it to the width you need.
  • Remembered per device: Your chosen widths are saved on your device, so panels reopen exactly as you left them.
  • Smart bounds: Panels can be resized up to half of your screen width, and automatically adapt when the opposite panel is maximized or fitted, so you always keep a usable layout.
Note: on small screens and mobile devices, panels keep their existing fluid behavior — resizing is not applicable there.
Freer Image Uploads for Textbox
Use your devices Images directly in Textbox: Upload an image straight into a Textbox Web App instead of only linking to an existing one. It supports common Web formats and will on the fly select the most optimized version to render based on your device resolution.
