xApps (xDesign, xShape etc.)
xDesign
You can add roll curve or slide curve mate to the curve component of your model.
With improved machine learning capabilities, Mate Helper finds mate locations on multiple exterior faces.
You can open a model including manual or automatic screw joints created between two elements and animate the mechanism to move the elements along a rotation axis. It is possible to animate mechanisms with more complex configurations and to visualize the motion of mechanisms including screw joints. Please view below video for more information: |
xShape
It is possible to create and simulate complex models by creating mechanisms anywhere in the product structure. Please view below video for more information: |
xSheetmetal
Streamline design process with selection-based context menus for sketches Easily create detailed flat patterns and markings with new Point or Curve Mapping feature. Please view below video for more information: |
xFrame
3DEXPERIENCE SOLIDWORKS / SOLIDWORKS Connector
Conveniently share drawings to 3DSWYM communities from within SOLIDWORKS. Please view below video for more information: 3DEXPERIENCE SOLIDWORKS: SOLIDWORKS Add-in / Design with SOLIDWORKS: |
Social/ Web-Apps
3DDashboard
Some widgets let you now change their default names. For example, if you add a Web Notes widget, and need to customize the name that appears on the header, do the following. In the Title field enter the name you want for your widget and clear the Display App Name option. Benefits: This enhances the way that some widget titles can be customized. See the user assistance of your widget to know whether your widget title can be customized. This capability is now available for following widgets:
In addition to 3DDrive, you can now access PartSupply, which provides a comprehensible catalog of 3D Components. You can simply click on the 3DDrive Icon> Use the Arrow next to 3DDrive> Select PartSupply |
3DDrive
Platform admins would be able to activate/deactivate external drive (Dropbox, Google Drive, Box and One Drive) from Drive Control Center. Note: This functionality is available to Platform Admins only. |
Project Planning
The home page has options for opening a project and for managing recent and favorite projects. These options are available:
Table view is available for viewing and managing tasks. Benefits: As an alternative to the task board, you can view tasks in a table.
Benefits: Project Planning provides a Critical Path Method (CPM) that is commonly used in projects across all industries. For more information, see Critical Path.
An enterprise project includes a Restrict Assignee Access option. If you set Restrict Assignee Access to "true," Viewers and Non Members who are added as task assignees in the project can only edit these fields: Maturity State, Percent Complete, Attachments, Deliverables, and Comments. Benefits: Leaders and Authors can restrict editing access on tasks in an enterprise project. Please view below video for more information: https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:4/media:fU_N2Da1Sq-n_HDtnjY2Cw |
3DPlay
Collaboration between users and sharing comments is no more available only for document, it is now available for 3D contents whatever the source: 3DDrive, 3DSwym or 3DSpace. With Share as Comment , you can now share a comment on 3D content to communities or conversations. Session-related information such as render settings, viewpoint, measures, or sections, is stored with the comment. When a user clicks the comment, this information is retrieved and loaded with the 3D content. For more information, see Sharing Content. Benefits: Previously, it was only possible to share comments on PDFs. It is now possible to share comments on 3D content with other platform users. Please view below video for more information: https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:4/media:zpsZFQRUQ1u6Nbux-yeRuQ |
3DSearch
Benefits: This feature enhances your refining capabilities on search results. Before the introduction of this feature, when you applied multiple refinements, the resulting query combined by default the tag values under the same tag with OR, and tag values across different tags with AND.
Native apps now support the 6W Lifelike Search experience mode. This search mode gathers search results by What, Who, When, and Where categories. Benefits: This search mode makes it easier to discover and refine search results. |
3DWhiteboard
3DSketch
You now have the possibility to create a 3DSketch/3DWhiteboard in a conversation through the widget. |
3DStory
Please view the below link for more information: |
CATIA
Functional Generative Design
You can now restart an incomplete optimization to continue it from the point where it ended. Optimizations might stop because of a license interruption, a lack of drive space, or they might reach the specified maximum number of optimization cycles. In any of these cases, you can now restart the optimization once you remove the blocking issue. You cannot change the setup for an optimization and restart it. For example, if you change the convergence criteria or constraint values, you must start a new optimization. Benefits: Restarting an optimization saves the time and computing resources used to reach the original stopping point. The completed optimization has all the data and options as if it completed in a single run. For more information, see About Restarting Optimizations. |
Sheet Metal Design
You can now create a jogged bend with a line or a sketch including a line. Benefits: You can create several bends at once. For more information, see Creating Jogs.
When creating walls, tangent walls on edge, walls on edge with clearance, or sketch-based tangent walls on edge, the results faces are now simplified, provided the input support faces are planar.
You can now create mitered walls from edges with profiles consisting of lines and tangent arcs. Benefits: The command is enhanced as you can use not only segments as profiles but also lines and tangent arcs. For more information, see Create Walls from Edges Along Adjacent Edges. |
Design Optimization
You can interactively customize graphical, curve, plot, and chart properties for greater visual clarity. Benefits: Immersively view and customize graphs and their properties including for advanced stacks such as A2X with greater visual clarity. For more information, see Interpreting Results. |
xGenerative Design/Visual Scripting
Three new commands let you handle the value of the parameters you create. You can now:
Benefits: The management of parameters is enhanced. For more information, see Working with Parameters.
You can now provide textual and visual indications in your graph by inserting notes and images. Benefits: Notes and images are useful to annotate your graph and to provide explanations about your design. For more information, see Notes and Images.
Several new operators are added to the library.
Benefits: New design capabilities are provided. |
Mechanical Systems Design
You can create and manage mechanism parameters and use them in formulas to define specific properties of mechanism elements. Benefits: It is easier to define a specific behavior for mechanism elements using mechanism parameters and formulas. For more information, see Creating Mechanism Parameters and Formulas.
You can open a model including manual or automatic screw joints created between two elements and animate the mechanism to move the elements along a rotation axis. Benefits: It is possible to animate mechanisms with more complex configurations and to visualize the motion of mechanisms including screw joints. For more information, see Previewing the Motion of Mechanisms.
You can open a model including manual or automatic point-surface joints created between two elements (a point and a body surface) and animate the mechanism to move the elements according to one another. Benefits: It is possible to animate mechanisms with more complex configurations and to visualize contacts between two geometric elements using point-surface joints. For more information, see Previewing the Motion of Mechanisms.
The 3D accuracy option lets you visualize the effects of the mesh density on the accuracy of the contact surface in the 3D area. The 3D accuracy value cannot be edited and depends on the mesh density value. Benefits: By providing information about the mesh accuracy, performance and robustness are enhanced, especially for contacts with a fine mesh density, and it is possible to assess the resulting quality of the mesh. For more information, see Creating Contacts Between Bodies. |
Simulation Model Preparation
You can now create a watertight representation of your model and extract an exact geometric representation of its internal flow domain. This enhancement includes two new features:
Benefits: Closing gaps in the internal flow region and extracting its shape enables you to use the internal flow region more efficiently for fluid flow simulations. For more information, see Defining a Lid and Extracting the Internal Volume. |
xDrawing
Export 2D Drawings as DXF/DWG Output You can export 2D drawings documents as DXF/DWG output. Benefits: You can now share 2D drawing documents like DWG/DXF with manufacturing stakeholders. For more information, see Creating 2D Output. |
x3D Design
While creating new components, you can now choose bookmark folders for the components from the home page of the app or by using the New command on the Standard section of the action bar. Benefits: The ability to select a bookmark folder while creating components makes it easier to organize your work. For more information, see Bookmarking Components.
While creating sketches, you can snap to spline and ellipse geometries within, and external to the active sketch. Benefits: This snapping ability with splines and ellipses is available during the entity creation and in drag operations. The snap creates coincident constraints to the splines and ellipse curve.
You can open models including curve-related joints and animate them using the Kinematics Player. Curve-related joints include the following:
Benefits: When working with motion models and switching between apps that include a Kinematics Player, you use the Kinematics Player to simulate the motion.
You can create mechanisms under any product of your model and not only under the root product. Benefits: It is possible to create and simulate complex models by creating mechanisms anywhere in the product structure. For more information, see Creating Mechanisms.
You can open a model including manual or automatic screw joints created between two elements and animate the mechanism to move the elements along a rotation axis. Benefits: It is possible to animate mechanisms with more complex configurations and to visualize the motion of mechanisms including screw joints. For more information, see Previewing the Motion of Mechanisms. Reference Video: https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:4/media:4mPYrySLRueQMwAMQ4ff0g |
SIMULIA
Linear Structural Validation
Structural Model Creation
Mechanical Scenario Creation
Fluid Scenario Creation
Efficiently interrogate simulations results via the ability to author fluid streamlines completely through the 3D viewer increasing intuitiveness and reducing user task time |
Plastic Injection Engineer
Structural Designer
Improve results interpretation by plotting heat flux components |
DELMIA
New Role: FACTORY SIMULATION ENGINEER (EFS)- Added to 3DEXPERIENCE Engineer (U2R)
New App: Factory Flow Simulation available for 3DEXPERIENCE Engineer
It enables you to Simulate material flow and resource utilization in a Virtual Factory context.
New Role: ROBOT PROGRAMMER (RBS)- Added to 3DEXPERIENCE Engineer (U2R)
New App: Robot Programming Essentials
It provides robot programmers with a comprehensive and robust set of capabilities:
