Zero thickness geometry issues with extruded cut on boss-base Loft
Good evening Solidworks aficionados.
I've run into a peculiar problem attempting to perform an extruded cut on a lofted boss-base part. I'm trying to do an extruded cut from face using a closed sketch that uses curved converted from the loft. This results in a Zero Thickness rebuild error. You can see what I'm trying to do in faceExtrudedCut.jpg and the sketch with its referenced curves in sketch.jpg. While experimenting, I discovered that cutting through all will leave a razor thin surface running around the outer curve (see extrudeThroughAll.JPG) Despite the curve being supposedly identical to that of the sketch.
I've rebuilt the loft and sketches numerous times, sometimes running into similar errors on the other cut parts, sometimes not, with little apparent rhyme or reason.
After a lot of experimentation and a lot of digging on the internet I'm kind of out of ideas. If you could offer a solution or a better way to acheve what I'm going for I'd be most grateful.
I've attached the part to this post.
Cheers.
SolidworksParts And Features
Answers 12
JS
JS 2015-05-08 Best Answer
Stephen -
What I do in this situation is offset the outer line and make the line that you show a construction line.  Lofting at times has a weird twist in the surfacing and that will leave some material there
comment imagecomment image
IM
IM 2015-05-08
John, Exactly what I was getting at, but you beat me to it.  In that case I´ll just let the images speaks for itself. Pay attention to the surface curvature combs on a face made of arc vs the face that looks like made of arc in your loft (blue ones). And because of the twisting the arc line becomes a spline.
comment imagecomment imagecomment imagecomment imagecomment imagecomment image
SF
SF 2015-05-08
Thanks for the replies, guys.
The problem with these solutions is that if I extend the sketch beyond the borders of the loft, I'll get a projection error - I'm trying to cut a curved inset into my loft, similar to the others that have already been cut.
IM
IM 2015-05-08
Can you be more specific ?
SF
SF 2015-05-08
Sure. If you look at FaceExtrudedCut.jpg you can see what I'm attempting - Extruded cut from the face of the loft model with a blind inwards cut of 0.75mm
IM
IM 2015-05-08
Like this ??, see attached.
IM
IM 2015-05-08
Probably not, I think I understand now. I´ll have a look.
DB
DB 2015-05-08
Looks like if you change the cut extrude  from selected contour to region things work out. Delete the "selected contour" and select the region of the sketch.
JS
JS 2015-05-08
I did try that Dennis, but a little differently and I couldn't get it to cut right, now I see what I did wrong and yes your method would work as well
IM
IM 2015-05-08
Tried various methods because of the ZTG, ended up with this one. See attached file.
JS
JS 2015-05-08
I found a solution but im using SW2014 so you won't be able to open my file. But here are the steps I used:
1. Make a copy of the top surface using Offset surface.
2. Extend the edges of the new surface so they stick out past the old one. .20mm worked for me, I tried larger at first but it went weird.
3. Modify the cut sketch to extend past the part boundary but stay within the new surface boundary. I did .10mm out.
4. Now do your cut from the new surface, blind .75mm.
5. Done.
comment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment image
SF
SF 2015-05-09
This one is a nice, elegant solution.
Thanks so much guys. You have all been amazingly helpful.
