Why would you ever want to use mirrors/linear/circular patterns on a single hole wizard hole to create a hole pattern on a surface?
This seems quite silly.
  1. It clutters up your design tree and makes you click around to find what a thing actually is.
  2. it messes up your ability to use pattern driven component patterns
Putting the mirror/linear/circular pattern inside the hole wizard feature is there, presumably, because SW thinks it's a better way of doing it. It's cleaner. You can access every control for the hole pattern from one place. It actually works with pattern driven component patterns.
Is there some computational advantage to using patterns outside of the hole wizard feature?
