Why won't the 2015 Parametric Study change the geometry between design points?
Hi!
I'm trying to analyze a flow problem using Solidworks 2015 with the Parametric Study. I created several different design points, varying different dimensions of the part, but as I run the parametric "What If" study, it seems to run the same geometry over and over again, regardless of the specified dimensions. The only way I have found that I can do this is by changing the dimensions one at a time, running one simulation after another.
Any help on this would be greatly appreciated!
Jorgen
SolidworksSimulation
