VBA - Replace Multiple Selected Components
  I have a case I need to replace multiple details in an assembly with a known set of replacement parts. I would like to either select the parts from the feature tree or the model window. Files are in a known path. (Attached zip has reference part files & assembly file)
This version, selection is only handled from the feature tree
My issue is …if I select any 1 single file it works fine, if I select more than 1 file the macro runs, but replace ALL parts with the same part.
Example
Original files
PartA-1
PartA-2
PartA-3
Replace With
PartB-1
PartB-2
PartB-3
Macro of what i have is below...
Option Explicit
Option Compare Text
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim activeModel             As SldWorks.ModelDoc2
    Dim swAssy                  As SldWorks.AssemblyDoc
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swSelComp               As SldWorks.Component2
    Dim swSelModel              As SldWorks.ModelDoc2
    Dim vChildComp              As Variant
    Dim swChildComp             As SldWorks.Component2
    Dim sPadStr                 As String
    Dim i                       As Long
    Dim CfgName                 As String
    Dim FileName                As String
    Dim bRet                    As Boolean
    Dim nErrors                 As Long
    Dim ret                     As Long
    Dim swCompModel             As ModelDoc2
    Dim boolstatus              As Boolean
    Dim swModelDocExt           As SldWorks.ModelDocExtension
    Dim IsToolBoxPart           As Boolean
Sub mainA()
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Set swAssy = swModel
    boolstatus = swApp.SetUserPreferenceDoubleValue(swUserPreferenceDoubleValue_e.swViewTransitionHideShowComponent, 0)
    Dim LWerrors As Long
    LWerrors = swModel.ResolveAllLightWeightComponents(False)
    If swModel Is Nothing Then
        MsgBox "No active Assembly document"
        Exit Sub
    End If
    If swModel.GetType <> 2 Then
        Exit Sub
    End If
    Set swSelMgr = swModel.SelectionManager
    If swSelMgr.GetSelectedObjectCount2(-1) = 0 Then
        MsgBox "No selected component", vbExclamation
        Exit Sub
    End If
    Dim selCount As Integer
        selCount = swSelMgr.GetSelectedObjectCount2(-1)
        selCount = selCount - 1
            Dim i As Integer
            For i = 0 To selCount
                Set swSelComp = swSelMgr.GetSelectedObject6(i + 1, -1)
                Set swCompModel = swSelComp.GetModelDoc2
                Debug.Print swSelComp.Name2
                If swSelComp.IsSuppressed = False Then
                    ret = swCompModel.Extension.ToolboxPartType
                End If
                If ret <> 0 Then
                    MsgBox "Part selected is NOT a fastener", vbExclamation
                Exit Sub
                End If
                If ret = 0 Then
                    FileName = ""
                    CfgName = ""
                    CfgName = swSelComp.ReferencedConfiguration
                    If InStr(swSelComp.Name2, "PartA-1") Then
                        FileName = "C:\\Test Data\\REF Package\\PartB-1.sldprt"
                    End If
                    If InStr(swSelComp.Name2, "PartA-2") Then
                        FileName = "C:\\Test Data\\REF Package\\PartB-2.sldprt"
                    End If
                    If InStr(swSelComp.Name2, "PartA-3") Then
                        FileName = "C:\\Test Data\\REF Package\\PartB-3.sldprt"
                    End If
                    bRet = swAssy.ReplaceComponents2(FileName, CfgName, False, 0, True)
                    FileName = ""
                    CfgName = ""
                End If
            Next
End Sub
SolidworksApi/macros
