Using the Solidworks API alongside the Document Manager API
I'm using the Document Manager API alongside the regular Solidworks API to access the same model document. The reason for this dubious practice is that I need access to the InvisibleCustomProperty methods that the DM API provides and features of the model document. I'm not aware of a way of setting InvisibleCustomProperties through the normal Solidworks API.
My problem is that, when I set the property, save the document, and then re-open it. The invisible custom property doesn't exist anymore. This behavior isn't consistent - sometimes it does manage to save. If I rebuild the open Solidworks Model and then save it, the InvisibleCustomProperty is gone.
To combat this problem, every time I attempt to read from, write to, or create the InvisibleCustomProperty, I wrap the execution in this pair of functions:
Private Sub getDMDocWriteAccess()
    Dim open_error As SwDmDocumentOpenError
    Dim bRet As Boolean
    'make the model document read only before opening
    If pModel.IsOpenedReadOnly = False Then
        pModel.Save
        bRet = pModel.SetReadOnlyState(True): Debug.Assert bRet
        Debug.Print "Set the model document to read only"
    End If
    Debug.Assert Not (pModel.IsOpenedReadOnly = False)
    Set pDMDoc = pDMApp.GetDocument(pPathName, SwDmDocumentType.swDmDocumentPart, False, open_error)
    If Not open_error = swDmDocumentOpenErrorNone Then
        Set pDMDoc = pDMApp.GetDocument(pPathName, SwDmDocumentType.swDmDocumentPart, False, open_error): Debug.Assert open_error = swDmDocumentOpenErrorNone
    End If
End Sub
Public Sub saveAndCloseDmDoc()
    Dim save_err        As SwDmDocumentSaveError
    Dim reload_err      As swComponentReloadError_e
    Dim swDMDocument    As SwDocumentMgr.swDMDocument
    Dim bRet            As Boolean
    Set swDMDocument = pDMDoc
    save_err = swDMDocument.Save: Debug.Assert save_err = swDmDocumentSaveErrorNone
    swDMDocument.CloseDoc
    bRet = pModel.SetReadOnlyState(False): Debug.Assert bRet
    reload_err = pModel.ReloadOrReplace(False, pModel.GetPathName, True): Debug.Assert ((reload_err = swDocumentNotChanged) Or (reload_err = swReloadOkay))
End Sub
For instance, setting the custom property is implemented in this way:
Public Sub setValue(value As String)
    getDMDocWriteAccess
    createCustomProperty
    pDMDoc.SetInvisibleCustomProperty pCustomPropertyName, value
    If Not (StrComp(pDMDoc.GetInvisibleCustomProperty(pCustomPropertyName, swDmCustomInfoText), value) = 0) Then
    End If
    Debug.Assert (StrComp(pDMDoc.GetInvisibleCustomProperty(pCustomPropertyName, swDmCustomInfoText), value) = 0)
    Debug.Print "SET VALUE:" & pDMDoc.GetInvisibleCustomProperty(pCustomPropertyName, swDmCustomInfoText); ""
    saveAndCloseDmDoc
End Sub
These are all in a class with private variable names starting with "p" in those examples.
The macro runs without any of those debug.asserts throwing. However, the problem persists - the InvisibleCustomProperty does not persist.
The trouble I'm having with debugging this is I feel like I can't trust the return values for the DMDocument's save method and there isn't a way of observing the change when it is successful.
I would really prefer to use this functionality because it would prevent user-error and allow me to write future macros that use this value purely through the Document Manager API.
SolidworksApi macros
