Unphysical heating under high pressure
Hello -
I am trying to model a high-pressure nozzle in SolidWorks Flow Simulation and I get unphysical results.
Specifically, I have a very simple system, which is a combination of stock pipe (inlet/source) and stock nozzle (outlet/sink).
The inlet mass flow rate is ~1 lb/s, which gives me the inlet pipe pressure of ~10,000 psi.
The inlet temperature is set at 80F.
Liquid - water.
However, when I model this configuration the water in the inlet pipe heats up to unphysical temperatures, which go up with the flow rate.
I get hundreds of degrees F in my inlet pipe, which cannot be correct. So, what's wrong? Is SolidWorks incapable of accurately modeling fluid flow with pressures in the thousands of PSI range?
Thank you in advance,
MAX
SolidworksSimulation
