Good Friday to you all!
I have a macro that should suppress all hardware(we name them with a 5 number) but for some reason it just isnt suppressing them. Anything you can tell me will be helpful.
Ive included my code for perusing.
Thanks,
Trevor
Option Explicit
Dim boolStatus As Boolean
Dim feat As Object
Dim featureName As String
Const SWDOCPART = 1
Const SWDOCASSEMBLY = 2
Const SWDOCDRAWING = 3
Dim vConfigName As Variant
Dim sConfigName As String
Dim i As Long
Dim swConfig As SldWorks.Configuration
Dim swSubFeat As SldWorks.Feature
Dim subFeatName As String
Sub main()
Set swModel = swApp.ActiveDoc
Dim configMgr As ConfigurationManager
Dim C1a As Configuration
Dim selMgr As SelectionMgr
Dim res As Variant
Dim itemNumber As String
Set selMgr = swModel.SelectionManager
Set configMgr = swModel.ConfigurationManager
swModel.ShowConfiguration2 ("Default")
'New code to find configuration names
Set swConfig = swModel.GetActiveConfiguration
vConfigName = swModel.GetConfigurationNames
For i = 0 To UBound(vConfigName)
sConfigName = vConfigName(i)
Set swConfig = swModel.GetConfigurationByName(sConfigName)
If sConfigName = "Default" Then
ElseIf sConfigName = "NO HARDWARE" Then
'make flat pattern active configuration
swModel.ShowConfiguration2 ("NO HARDWARE")
Set feat = swModel.FirstFeature
Do While Not feat Is Nothing
Let featureName = feat.Name
itemNumber = Left(featureName, 1)
If itemNumber = "5" Then
res = swModel.SelectByID(featureName, "BODYFEATURE", 0, 0, 0)
res = swModel.EditSuppress()
Set swSubFeat = feat.GetFirstSubFeature
While Not swSubFeat Is Nothing
Let subFeatName = swSubFeat.Name
res = swModel.SelectByID(subFeatName, "BODYFEATURE", 0, 0, 0)
Set swSubFeat = swSubFeat.GetNextSubFeature
Wend
Else
End If
Set feat = feat.GetNextFeature()
Loop
'set back to the correct configuration
End
End If
Next
'End new code
'create flat pattern configuration
configMgr.AddConfiguration "NO HARDWARE", "NO HARDWARE", "Alternate Name", 1, "Default", "no description"
res = swModel.EditUnsuppress()
Wend
Else
End If
Loop
End Sub
SolidworksApi macros
