I am running SW2008 Premium with SP5.0.
This is a bit of a fishing expedition but figured it couldn't hurt to ask. My workstation has become unstable with SW and our lone IT/Network sort of guy is way too busy to pay attention to us CAD folks. So I am digging into it myself.
My workstation was built in-house. It consists of an Intel Core2 Quad 2.4 GHz processor, 4 GB Kingston ram, Intel 975X MB, Window XPPro 32-bit with SP3 and running 3G switch, 250 GB Segates in RAID, dual monitors, Space Pilot, PNY NVidia Quadro FX4600 with driver 6.14.11.6265 (currently installed) and 6.14.11.8246 (previous).
I have been using this system for a couple of years without issue. It started acting flakey around Thanksgiving. The symptoms are as follows:
- Windows Picture & Fax View reports 'drawing failed' as I parse through several images on a network shared area. Not every picture fails. A failed picture may view fine when I return to it.
- Adobe Reader 8.1.7 will launch and show the first page, but when I scroll the image remains fixed except for about an inch at the bottom where I can see the pages rolling by.
- NVidia desktop manager allows different backgrounds on each of my dual monitors. I had some personal pictures displayed for a long time. These now show up briefly as the system boots and then disappear to the Windows background color. NVidia says the pictures are there in the control panel.
- SW background upon initial bootup is black instead of showing the DeSault/SW logo.
- SW Property managers will often show only some of the graphics. Does not seem to be limited to a specific property manager. Feature manager seems fine.
- If SW launched a second time without a system reboot, often cannot find networked resources. Launching windows explorer to the same network drive will pop an error message along the lines of 'not enough resources to perform this task'. Does not happen every time. Other users in the office not having the same issues and retaining full access to networked resources.
- Just this morning SW popped a message along the lines 'OpenGL being launched because..." Never seen that one before. Could my graphics card be tanking?
I was running video driver 8264 for quite a while. Then when I started having the picture viewer problems our IT guy found a KB article on MS that said to reinstall the video drivers. I did and it fixed the problem - for a while. Then I started having all the other problems. When I changed the driver, I completely uninstalled the old driver. Rebooted the system, cancelled the "found new hardware" message and manually launched the driver installation.
After not regaining stability I have gone through this exercise several times. I have bounced back and forth between the two drivers. I have performed a system error check and defrag between installations. I keep close tabs on services and task that are running and get rid of all the 'auto' updaters and other sneaky-ware. I have not installed any new (different) software - but do get updates. My machine is not dedicated to just SW. I typically have Outlook running, a web page or two, a network folder open, etc. However, I have used the machine this way for a couple of years and its performance was very consistant.
We changed corporate virus software about six months ago from F-Secure (off subject... I really like this stuff) to Symantic (not its biggest fan). In December we had a lengthy power outage. The battery backup infrastructure in our server room was modified (not robustly) and caused several of the servers to shut down hard. They were problematic afterwards but have all been rebooted. Others in the office report they are not having issues.
I know this is not much to go on, but I would enjoy hearing what usual or typical steps you go though or places you check on your systems in a case like this. Are there some registry areas to dig into? I just discovered a reference to the Windows Performance Monitor utility on these discussions. Looks like a handy tool... if I knew how to put it to good use.
Thanks in advance.
Daen
SolidworksAdministration
First steps I would try;
1) Disable Symantec
2) Remove Symantec
3) Ban Symantec from the building
4) Add /USERVA 2900 option after the /3GB switch
5) If possible try switching video card with another user, or at the very least, remove, clean contacts with pink eraser and replace.
Get CCleaner (http://www.ccleaner.com/) and run it. It's free and has never caused me any grief. It'll clean up all the residual crap on your hard drive. It will also take care of dangling .dll's in your registry.
It could just be time to reformat, too.
My thoughts also on the 3GB switch and the video card swap. You might try booting and running for a day without the switch to see if things change. The symptoms of lacking resources sounds like when I was testing the switch and didn't have a low enough uservalue set. I have also seen video cards fail - especially the fan stopping. Make sure it's still running.
WT
It's hard to say what your problem could be...Are you having any other issues like save times getting longer? Maybe it's bad memory.
If it's just graphically related, other than your driver, I'd look into the graphics card going down the toilet.. I'm not sure if that happens much though and wouldn't know how to test it without physically swapping out cards.
I don't think it's your AV software but it's always possible.
Daen,
When I have problems like you are experiencing I start with a fresh install of the operating system. I find that many of the automatic updates that Microsoft will make to your OS to improve security, can cause degradation with your other applications and drivers. I usually gauge this by the number of processes running in the Task Manager. Although this sounds like a big pain, it is way easier than trying to track down all offending registry entries or throwing your complete trust in a registry cleaning software program.
I have my operating system on a separate Solid State Disk which makes the process very easy. I also have SolidWorks installed to that disk, but it is only 32 GB, so all applications will not fit. But you can buy an Intel 40 GB SSD which is best of class for only $129.00 at Newegg. I am going to upgrade to W7 and will do this by adding another SSD to my computer with W7. If that all works well, then I will get rid of the dual boot arrangement and the old SSD (and use it on another system or as an external drive or maybe even Ubuntu Linux).
Could be your total problem is with Symantic as Kevin suggests. I have Symantic on my workstation but operate with the virus protection turned off. I also don't run Outlook on my workstation because it does cause problems with SolidWorks, at least until SW2009 SP4.1 I use my laptop for Outlook and web surfing with virus protection turned ON.
I've heard of some people turning off the switch with success.
I also use CCleaner, good program to have.
"it is way easier than trying to track down all offending registry entries or throwing your complete trust in a registry cleaning software program."
True, you have to be careful what your removing from your registry.
Kelvin,
I also feel that Symantic is way more VIRUS than Protection... but the boss made the change and I am stuck. I am sure my overenthusiastic IT guy has my ability to shut it off disabled.
Since writing this a bit ago, I actually started messing with the /USERVA 2900 option. I tried it at 2800 and 2700 also.
One repeatable artifact I am noticing comes from trying to get you guys some screen shots. I launched SW and opened a random assembly - something from my recent documents list. I know that the Appearance Callout property manager has had graphics issues very consistently so I launched it. Sure enough. I don't get the OK or cancel at the top, the box with all the color squares is gone. One other time it launched and still had the features text showing through.
But I tried to create a print screen copy and paste it into Paint. Can't even launch paint while the appearance property manager is open. Once closed, paint will launch. But when I try to paste, I get an error that clip board data can't be accessed.
So I can't seem to make a screen shot to share and when the graphics problems are in full swing, it seems to permeate throught the system, not just within SW...
The video card physical cleaning I had not thought of.
Thanks to all for your quick and thoughtful suggestions. A system clean install is certainly an unpleasant thought...
Thanks, Daen
Definitely- if you are having a lot of little problems- blitz the hard drive and reload the operating system- remeber to back up first! and also de-activate solidworks before you start....
Especially in light of your power outage, (there may have been spike damage to your hardware,) some other possibilities include ...
Failing Hardrive
Failing Motherboard
Failing Power Supply
I second and third the recommendations on Symantec, the /userva settings, trying without the 3GB switch and a clean install on the OS
... and highly recommend getting yourself on a 64-bit OS
I know you said you regularly check for malware, but I'd run a malware detection software that also includes a rootkit revealer. A few of them are including it in their software package now, I prefer TrendMicro for AV with Spybot Search and Destroy, MalwareBytes, and SpywareBlaster for malware. HijackThis has a manual rootkit revealer if nothing else, but you need to kinda know what you're looking for, or not looking for rather.
I agree with Shawn, in light of the power failures you have had and a bit of an older system I would suspect you have some hardware failing in your system. I would look at the power supply first. Then the rest of the major components, RAM, video card, mother board, hard drive.
I would also look to see how clean the power is coming out of the plug in your office. We had a system that was always flakey. One day, by accident, we realized the wall plug was not properly grounded. Fixed that and the problems went away.
You may try a power conditioner to plug your computer into. I use this on my home system. http://www.opti-ups.com/Products/Item.aspx?model=SS2000
I would probably wipe the hard drive clean and start over too. Space dust builds up over time on systems and wiping the hard drive clean and re-installing the OS can help a mulitude of problems.
I would dump Symantec too.... :-)
Cheers,
Anna
Daen,
I'm not a fan of Symantec either, but I doubt that is the issue. Symantec version 11.x has a pass grade with Solidworks. Check here for antivirus pass/fail grades. http://www.solidworks.com/sw/support/AntiVirus_SW.html
I would rethink the 3GB switch, especially if you like to have outlook running. The 3GB switch should only be used if you are getting a "running out of system resources" messages, and then it might be time to think 64bit system and more RAM. Obviously there is alot more to that discussion, but that's the skinny.
I've seen the black screens and such, and it always seems to point to the video card. I have the FX4500 and it's very nice, even though it's old. Your FX4600 is a high end card, so it's should be fine with the right driver. Might want to take your system apart do a nice cleaning and dust removal to keep the heat down on the card. A key is if the problem gets worse as your day goes on.
Do you shut down every day?
With all the wierd things going on with your system I would think it's hardware related. Bad memory can cause all sorts of wierd things, dying hard drives too. My first suggestion would be to download Memtest, burn an Iso to CD & boot with memtest in the drive, let it run all night & see if you have any errors in the morning, if your have a bad stick of ram you will see errors.
Anna & Shawn,
Thanks for the great suggestions. Just to clarify, the power outage and hard shutdown occurred to the company servers, not my workstation. My workstation is powered by an APC ups with the graceful shutdown procedures enabled.
...however, I didn't actually witness it in the wee hours this particular time....
FYI - We are running Symantec Endpoint Protection 11.0.4014.26
Outlook is via an exchange server if that makes any difference in its resource footprint.
We modified all of our CAD stations to the 3G switch because our assembly was a couple thousand parts and getting difficult to manipulate. The others are not seeing the same issues. All the CAD boxes are very similar vintage, some are running a slightly older dual core on a 955 MB and an FX4500. All other components the same.
The idea of x64, Win7, etc is very appealing to me. However, I am up against the same issues as every other small businss - several CAD stations to upgrade simultaneously, convincing the boss to spend more money, the IT guy thinks our 2000 vintage servers running Server2000 and 2003 have tons of life left in them and MS will continue to support XP for eons!
I do leave my machine running. For 18+ months with heavy SW usage I could get away with a reboot every four to six weeks. Very stable and hearty system. So you can understand the grimace on my face now that it has developed an attitude.
Fred,
I didn't have quick access to your Memtest, but did run Intel Desktop Control Center Stress Test for about 5 minutes (I'll let it run over night when I leave the office). No errors and temperatures stayed rock solid. I'll give an update after tonights run.
Thanks for the suggestion.
Daen
I ran the stress test all night. This test (available from Intel) is actually from Passmark Software http://www.passmark.com/intel/support.htm.
No errors and here is a summary of the results:
Time Expired - 15.5 hours
Test Cycles Ops
CPU 54134 24575160614430
MMX 19539 10787571981724
RAM 518 550400210944
2D Graphics 112 560495
3D Graphics 452465 1447888000000
Network 972970477837385600
Temperatures on the two monitored MB points actually cooled down a few degrees. I am sure the test puts all the fans at high speed.
Speaking of fans... I don't think heat is an issue. I monitor this and have not had problems. The box is a large Antec unit. BIG fan on the back, fans on Hard Drives, additional front fan below hard drive cages, fan on side panel for CPU, fan on side panel for Graphics Card, internal Power Supply fans, CPU fan on MB, internal graphics card fan.
Power Supply is reporting:
+12V 12.188
+5V 5.026
+3.3V 3.300
CPU Core 1.176
CPU I/O (+1.5V) 1.484
Daen
I finally had some time to examine my system and have had some positive results. I wanted to pass along what I found. Too soon yet to say the patient is healed, but things are looking good for now!
Our IT guy is out of the office for extended time and he has much of the installation software locked down (can't have us engineers messing with stuff even though I personally built all our CAD machines before his existence). I could not wipe my OS and reinstall until his return - no access to office / virus / networking, etc. So I started digging.
Symantec said all was good. But a friend provided a cocktail of free and fee-based anti spam / malware / bot tools. His take is that none of them get everything, but if you run the "cocktail" of them they do a pretty good job. Funny that many of them did not like the competitor software...
Well they managed to find a handful of unfriendlies - trojans, dropper, etc. I cleaned all of that stuff up and that helped a bunch. Sure glad Symantec is watching my back!
Next I found that SolidWorks had managed to turn Dissection back on. Who know how long it has been that way. The dissection folder was HUGE!
I cleaned out the startup in MSConfig of all the little helpers that keep sneaking in after every software update.
I got rid of Desktop Search Indexing.
I went through the installed programs and dumped several.
On top of all those maintenance type of things, I had planned to do some more hardware investigating. I had run the stress tests and found no problems as discussed in earlier posts. But since things seemed to really choke on network access type events I planned to install a network card and disable the onboard LAN just to see if the NIC had gone bad. I had been out of the office for a week and had turned the machine off. Before I left it was performing so poorly I wasn't sure it would even restart. Well I fired it up and it seems pretty happy - this before I started the digging listed above. All of the very repeatable issues that I planned to use as indicators to test the new network card were conspicuously absent.
My theory now is that either I have a problem that fixed itself (love those since they like to unfix themselves just as mysteriously) or the problem was at the other end of the wire (server room). The IT guy has assured me there could be no problems there... The first two-week rest for my machine while I was out of the office wasn't enough, but the second one-week rest seems to have cured all. Go figure.
As it stands now it seems quite usable. Boot times are back to snappy. I opened our largest assembly in SW and it behaved better than in a long time. I have yet to put many miles on the condition to see if it is stable, but hopefully I have actually fixed things and can avoid a rebuild.
Thanks for all the suggestions previously. If things start acting up again I'll issue a follow-up.
Daen
