I have a simple Part created using an extruded cut to make hole then patterning and mirroring hole to achieve correct pattern. I then Converted entities to a new sketch on that part. So any changes to part updates this sketch. Then I save that driven sketch as a block in Library. However, a change to original part does not update the Library part. If I open the block saved in library there is no constraints as it is a driven sketch. I would have to edit original part resave sketch as block and overide original. Is there a way to make a block linked to an original sketch?
the idea here is that I could insert block to give me correct hole pattern to accept original part.
