Simulation Bolted Assembly - How to copy connectors?
Large flange pair connected with 36 bolts....  Help file says that when you create a connector (in this case a standard bolt) on a patterned hole feature, it will propogate so you do not have to re-create the same fastener over and over.
It does not work...or at least I can not figure out how to make it work.  The help is very deficient in this area.  Here is what it says....
Hole Series
  • When you add a bolt to one hole in a hole series, the software allows propagating bolts to all the other holes in the hole series.
  • The software groups the connectors based on the hole series in a separate folder.
  • Editing any one bolt in the group applies to all connectors in the series.
  • You can dissolve the bolt series and break the link to allow editing of each feature separately. Right-click the folder containing the series and select Dissolve Bolt Series.
  • You can restore the connector series after you dissolve it. Right-click the folder that contained the series and select Reestablish Bolt Series.
Anyone know the trick to make this work?  I have tried patterning the hole on the bolt circle in the part 3 different ways...and it will not pick up the pattern  Very poorly implementend feature, in my opinion....
SolidworksSimulation
