Setting Sheet Metal Gauge Table Via API
Good Morning to you all!
So my eventual goal is to take a sheet metal part with all manually entered values and change it so they use a gauge table and bend table. I have an idea of how i need to go about doing this but am getting caught up in some code that is from the solidworks help.
Right now I am trying to set the gauge table path but it keeps throwing up an error(telling me that the object or with variable are not defined) and I am unsure as to why. I would be willing to bet that I am misisng some slice of code but everything looks correct. Keep in mind that I'm just beginning to work on this so it is a bit sloppy because I havent added everything in yet.
Thanks in advance for any help you can give me!
-Trevor
Dim swFeat As SldWorks.Feature
Public swSubFeat As SldWorks.Feature
Public swSelMgr As SldWorks.SelectionMgr
Public Const STOCK_XREF As String = "J:\\CP LIBRARY\\CP-KRAUSE MATERIAL REFERENCE.xlsx"
Public Const CP_STEEL As String = "J:\\Toolbox\\Templates\\Ga. Tables\\CP-STEEL.xls"
Public Const CP_BEND As String = "J:\\Toolbox\\Templates\\Ga. Tables\\CP-BEND DEDUCTIONS.xls"
Public kStock As String
Public cpStock As String
Public customPropertyMgr As SldWorks.CustomPropertyManager
Public boolStatus As Boolean
Public gaugeTable As String
Option Explicit
Function Stock_Convert()
Dim myExcelApp As Object
Dim xlSheet As Variant
'Open excel workbook
Set myExcelApp = CreateObject("Excel.Application")
myExcelApp.Visible = False
myExcelApp.Workbooks.Open FileName:=STOCK_XREF
'get cpStock from .xls file
Set xlSheet = myExcelApp.ActiveSheet
Dim y As Double
y = 1
Do While y < 10000
    If xlSheet.Cells(y, 3) = kStock Then
        cpStock = xlSheet.Cells(y, 1)
        Exit Do
    Else
        y = y + 1
    End If
Loop
End Function
Sub Process_SMBaseFlange _
( _
    swApp As SldWorks.SldWorks, _
    swModel As SldWorks.ModelDoc2, _
    swFeat As SldWorks.Feature _
    Debug.Print "  +" & swFeat.Name & " [" & swFeat.GetTypeName & "]"
    Dim swBaseFlange                As SldWorks.BaseFlangeFeatureData
    Set swBaseFlange = swFeat.GetDefinition
    swBaseFlange.UseGaugeTable = True
    swBaseFlange.GaugeTablePath = CP_STEEL
    'Debug.Print "    Gauge Table = " & swBaseFlange.GaugeTablePath
    'swBaseFlange.GaugeTablePath = CP_STEEL
End Sub
Sub Main()
Set swModel = swApp.ActiveDoc
Set customPropertyMgr = swModel.Extension.CustomPropertyManager("")
Set swFeat = swModel.FirstFeature
swFeat.Select2 True, 1
'get kstocknumber
kStock = swModel.GetCustomInfoValue("", "kstockNumber")
'figure out what stock number/material needs to be used
If swModel.GetType = 1 Then
    Stock_Convert
    Process_SMBaseFlange swApp, swModel, swFeat
Else
    MsgBox "Can only be used on parts, not assemblies"
    End
End If
End Sub
SolidworksApi macros
