Rolled Bar Flat Length Problem
I'm using the sheet metal function to create a rolled bar so I can have a flat pattern.  However, the flat length of the part is not correct.  SW's is giving me the flat length of the outside radius arc length, not the neutral axis.  What am I doing wrong?
Need to roll a 2x4 steel bar in the hard direction, i.e. 4" direction with an 88" outside radius and an angle of 90°.  This will give a flat length of:
Rad of neutral axis*2*π*(angle/360) = 86*2*π*(90/360) = 135.09.
SW's flat length derived from the outside rad:
88*2*π*(90/360) = 138.23
I created my model from a sketch with a 90° arc and 88" rad.  Then I used the base flange feature with a direction 1 of 2" and sheet metal thickness of 4" and a K-factor of 1 to ensure SW doesn't add a bend deduction.  SW automatically creates the flat pattern with the length equal to the arc length of the outside radius.  What am I doing wrong?
SolidworksSheet Metal
Answers 9
JF
JF 2013-09-13 Best Answer
the k-factor determines where SW calculates the neutral axis to be. 0 = inside edge, 1 = outside edge. if you want to assume the neutral axis is in the center, your k-factor should be .5.
SF
SF 2013-09-13
I have "Use guage table" unchecked and selected K-Factor under Bend Allownce.  I set the K value to 0, .5, and 1 and the flat length is always 138.23.  I'm regen'ing the part after each change.  Any ideas?
JF
JF 2013-09-13
I followed the steps you listed and I get a flat at 135.0885" with a kfactor of .5 - see attched
AW
AW 2013-09-13
Wayne,
Can you post a part that is not working for you for us to look at?
Cheers,
Anna
SF
SF 2013-09-13
I see your model works just fine, just changing the k value changes the model.  For some reason with my model I have to change both the radius parameter and the k value in order for the change to take effect.  I've attached my model if you're interested in see why mine acts this way.  If you find anything, please let me know so I can learn.
Thanks
AW
AW 2013-09-14
Click on the plus sign in your Sheet Metal folder to expose the Sheet Metal settings  for each body.
Uncheck the over-ride toggle.
You have the ability to control the Sheet Metal settings for each body in a multi-body sheet metal part.  You want to be aware that your settings in the top level folder and for the body are not in conflict.
I think that is where you are getting your difference.
Cheers,
Anna
Cheers,
Anna
comment imagecomment image
SF
SF 2013-09-16
Thanks Anna.  I will play around with this to see what happens.  Why does my part have the additional sheet metal feature (the plus sign) but the part that Jeremy created doesn't.
AW
AW 2013-09-16
I believe Jeremy is using an earlier version of SW.  SW2013 changed some behavior here to help with multi-bdy sheet metal parts from earlier versions.
Cheers,
Anna
JF
JF 2013-09-16
yep - still on 2012 here.
