I have a nonlinear analysis with pressfits where I am tring to investigate two items. Item #1 total assembly delfection; item #2 contact pressures of press fits during loading. So what I am attempting to do is apply constraints on the assembly as needed during the inital steps of the anlaysis for the shrink fits to be applied, and then remove the constraints (using a time curve) to allow the assembly to respond to the applied external loads correctly. Has anybody done this before (removing constraints after shrink fit)? the results I am getting seem to indicate the the contraints in question are not being reomved (comparing static results to nonlinear results) It seems, without the inital constraints, the shrink fit contact condition will not solve, and with the initial constraints, the assembly will not respond correctly to external loads. Any advice would be appreciated. Thanks.
SolidworksSimulation
Steve,
I'm not familiar with how this is handled in SW Simulation, but I have run into similar problems with Ansys. There didn't seem to be a way to apply a constraint and then remove it in a later time step. I ended up putting in moving pieces that were rigid compared to my plastic part. I would place them in position to act as constraints on my plastic part while I inserted the mating part, then move them out of the way in a second step, add my external loads in a third step, and remove my loads to see what the residual stress or deflection was in a fourth step.
Jerry Steiger
You're right there's no switch to turn-off the displacements with a time curve (i.e., you go to "0" on the time curve and the displacement fixture holds it at zero instead of releasing the restraint). I have resorted to using a force on a time curve, or as Jerry suggested using another part.
Not sure if this applies to your particular study, but as far as applying constraints and then "removing" them later, there is a way to effectively pass thermal data as initial values into a new study, and then re-define constraints as desired...Regis Wacheux had some helpful information in this thread:
https://forum.solidworks.com/thread/48367?tstart=0
Not sure if that helps at all, but figured you'd want to at least have a look!
- T
Just wanted to say I was looking for the same ability. Frustrating that we cannot suppress restraints in later time steps, but at least now I know that I'm not missing a checkbox somewhere.
For what it's worth, my VAR suggested running the analysis with an artificially short time step & then restarting the analysis with the displacement suppressed. Not sure that will work either, but it's what I'll be trying next.
-Thanks
-Chris
in Cosmos/M they had at a special # you could put in like 1e-6 or something similar and it would "relax" the constraint. I was under the impression at one point that this would work in SWX Sim but alas that is, apparantly, not the case.
The bcs are not something you can change in a restart.
Should be specific. You can add and extend, but you cannot change or suppress.
Force is the only method. You can then set it to zero.
Depending on the conditions, you can also add supplementary geometry to get things in place and then move them away if you need displacement control .
Howdy,
I also wondered about this capability as did a customer so I checked with support and the magic number is: ......." 1e-8 "
as shown in the help:
http://help.solidworks.com/2014/English/SolidWorks/cworks/t_setting_post-cooling-phase.htm
non-linear dynamic studies would seem to be the best application since this would be a pretty "unstable" condition after releasing if the body is loaded up.
-Dave
in this case the load needs to be on and then off, do we know that it works that direction?
@Jared,
Yes it works both ways. Here's the quick example support was kind enought to throw at me.
http://youtu.be/3m6gBc7R9_Q
The fixture is used to pre-load by 10mm and then released to oscillate. As you can see if you try that with a static study , probably wouldn't have any luck converging.
Cheers,
-D
this is a great feature, i'm surprised none of the SPRs for this functionality have been marked as implemented.
have you tried it with a static nonlinear? i would mostly see it being used to hold something in place while a load is being applied and then remove it to let the rest of the application do its thing.
Way to go Dave. Thanks for sorting this out. I had heard it was suppose to work but when I had tried it out a release or two ago - might have been that I did not have the right number, it didin't work....anyway glad to hear it is good to go next time when it comes up.
Thanks for finding this & prooving that it works. Much appreciated!
Great idea although for me it did not work in my static non-linear analysis and did release the fixture in the second half of the simulation while running the restart from 1sec to 2 sec.
can you please clarify your statement. It sounds like it didn't work but did. It works if you restart but not if you do not do a restart?
Since 2016 you can set an applied displacement to off using a time curve.
What you still can't do is turn off / on a contact set, I have just submitted an enhancement request for this.
I never had any success with Restarts
