Remove existing configuration feature to replace control with design table
I created a part file with a few global variables. I then linked the global variables to certain feature dimensions. I then went and selected the linked dimension using the right mouse button and chose to configure the dimension. This all worked as planned, however, I know want to drive the model using a design table.
When I add the global variable to the design table, it does not assume contol of the dimension which had already been configured using the method described above. Can someone please direct me to a method in which I can remove the existing dimension configurations so that the design table will be able to control all aspects of the model without simply reverting back to the dimensions as they were originally configured.
Hope what I have explained makes some sense to someone.
Thanks
Wayne
SolidworksConfigurations design Tables
