Problems with SetSuppression2 and ClearSelection2
Having problems with getting SetSuppression2 and ClearSelection2 to work on selected components from FeatureManager. SetSuppression2 not changing the component to the choice of suppression and ClearSelection2 not releasing. Create an ASSY then add some Sub ASSY and PARTS. Make sure they are fully resolved and select a couple from the FeatureManager and run Macro. Look at debug screen. Suppression STATE should be 1 not 2 on components. Running SW2009 SP3 on Vista 32-bit.
' ------------ START CODE ------------
Option Explicit
Sub main()
    On Error Resume Next
    Dim swDoc As SldWorks.ModelDoc2
    Dim swSelMgr As SldWorks.SelectionMgr
    Dim swComp As SldWorks.Component2
    Dim CompArry() As Variant, CompCnt As Long, CompSelChk As Boolean
    Dim nSelCount As Long
    Dim CompSSSC As Integer
    Set swDoc = swApp.ActiveDoc
    Set swSelMgr = swDoc.SelectionManager
    nSelCount = swSelMgr.GetSelectedObjectCount2(-1)
    If nSelCount < 1 Then
        Debug.Print "Selected Components = " & nSelCount & vbCr & "Select Components from FeatureManager and run again." & vbCr
        Exit Sub
    End If
    ReDim CompArry(0)
    For CompCnt = 1 To nSelCount
        Set swComp = swSelMgr.GetSelectedObjectsComponent3(CompCnt, -1)
        If UBound(CompArry) <= 0 And CompSelChk = False Then  ' Component Array doesn't exist - Create it
            ReDim CompArry(0): Set CompArry(0) = swComp
            CompSelChk = True
        ElseIf UBound(CompArry) >= 0 And CompSelChk = True Then  ' Component Array exist - Populate it
            ReDim Preserve CompArry(UBound(CompArry) + 1): Set CompArry(UBound(CompArry)) = swComp
        End If
    Next CompCnt
    For CompCnt = LBound(CompArry) To UBound(CompArry)
        Set swComp = CompArry(CompCnt)
        CompSSSC = swComp.SetSuppression2(1) 'swComponentLightweight
        Debug.Print "Comp: " & swComp.Name2 & vbCr & "--> State: " & swComp.GetSuppression() & vbCr & "--> Error: " & CompSSSC
    Next CompCnt
    swDoc.ClearSelection2 (True)
End Sub
SolidworksApi macros
