Problem with a sketch for Sketch Driven pattern for Hole Wizard feature
I have to model few parts like in the picture:
Few basic details about the part:
1. Part outlines and it's X/Y and X'/Y' dimensions are derived from a weldment (tube frame) outlines
2. Hole locations circled in red are defined by a corner points of a offset of part outlines
3. Distance between holes is done by a Linear Pattern with following settings
and this results in a pattern like
Problem with this approach is such that in the part shown I have to do three separate Linear Patterns. This means also three separate Pattern Driven Patterns in Assembly to populate the necessary mounting hardware. Also in drawings I have to to either three separate hole call outs or calculate the total number of holes by hand.
I know that this could be achieved by a Sketch Driven Pattern but due to the limitations of Linear Pattern in Sketching I would have to calculate the number of holes and spacing by hand.
Any ideas about an easy workaround? Making a one linear pattern and skipping instances is not an option as there should be a hole in every corner and spacing in X' and Y' will not be the same as the spacing in X and Y.
SolidworksParts And Features
