Hello everybody,
I have writen a vba macro whoch create one (or more) linear motor to move a sphere and make an animation. In fact, i want to study the displacement of different point in the 3 dimension of space. So my idea was to create sphere on solidworks, make an assembly where i place it, and then apply 3 motor (one for x composant of displacement, one for y and one for z) for each sphere. And after, i will just have to click one play and see the animation.
My problem i that my vba macro create all my motor with all the parameter, but when i click on "calculate the animation" and after on "play", nothing move.
I have to make on each motor:
- right clik
- modify
- change nothing and validate
And now, i click on "calculate the animation" and after on "play" and all move correctely !!
I don't understand what is appening......
Have anybody an idea ?
here is my code :
Sub main()
UserForm1.Show
If choix = False Then Exit Sub
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSelMgr As SldWorks.SelectionMgr
Dim swMotionMgr As SwMotionStudy.MotionStudyManager
Dim swMotionStudy1 As SwMotionStudy.MotionStudy
Dim swMotorFeat As SldWorks.SimulationMotorFeatureData
Dim swGravityFeat As Object
Dim boolstatus As Boolean
Dim swFeat As SldWorks.Feature
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
Set swSelMgr = swModel.SelectionManager
' Get the MotionManager
Set swMotionMgr = swModelDocExt.GetMotionStudyManager()
If (swMotionMgr Is Nothing) Then
End
End If
' Get Motion Study 1
Set swMotionStudy1 = swMotionMgr.GetMotionStudy("Etude de mouvement 1")
' Activation de l'onglet Etude de mouvement 1
swMotionStudy1.Activate
param = num_prem_sphere
num_point = 0
fichier_existe = True
While fichier_existe = True
num_sphere = num_point + param
condition = False
If type_gene = 2 And num_sphere = num_sphere_moteur Then condition = True
If condition = True Or type_gene = 1 Then
For j = 1 To 3
' Création de la fonction moteur linéair en objet data
Set swMotorFeat = swMotionStudy1.CreateDefinition(swFmAEMLinearMotor)
' Affectation moteur déplacement interpolé
swMotorFeat.InterpolatedMotor swSimulationMotorDrive_Displacement, 1
' Affectation direction
If j = 1 Then boolstatus = swModelDocExt.SelectByID2("", "FACE", 0.00200000000001, -1.108492668891E-04, -3.443181067269E-04, False, 0, Nothing, 0)
If j = 2 Then boolstatus = swModelDocExt.SelectByID2("", "FACE", -1.583789315305E-04, 0.001999999999981, 0.000056847285407, False, 0, Nothing, 0)
If j = 3 Then boolstatus = swModelDocExt.SelectByID2("", "FACE", 0.000087205541206, -3.416578816768E-04, 0.001999999999953, False, 0, Nothing, 0)
swMotorFeat.DirectionReference = swSelMgr.GetSelectedObject6(1, -1)
' Affectation du point d'application du moteur
boolstatus = swModelDocExt.SelectByID2("Point1@Origine@sphère-" & num_sphere & "@Assemblage1", "EXTSKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
swMotorFeat.Location = swSelMgr.GetSelectedObject6(1, -1)
' Affectation de l'objet de référence
Dim RelObj As SldWorks.Component2
Set RelObj = swSelMgr.GetSelectedObjectsComponent3(1, -1)
swMotorFeat.RelativeComponent = RelObj
If j = 1 Then dir_dep = "x"
If j = 2 Then dir_dep = "y"
If j = 3 Then dir_dep = "z"
'Chargement du fichier de données de déplacement
chemin_fichier = "C:\\Documents and Settings\\pmorandi\\Bureau\\resu_dep\\point" & num_point & "_" & dir_dep & ".txt"
boolstatus = swMotorFeat.LoadSplineData(chemin_fichier)
' Print the motor type
Debug.Print swMotorFeat.MotorType
' Create the linear motor feature
Set swFeat = swMotionStudy1.CreateFeature(swMotorFeat)
If swFeat Is Nothing Then
Debug.Print " ERROR: Creation of the motor feature failed."
Else
Debug.Print "Name of the feature added : " & swFeat.Name
End If
Next
End If
num_point = num_point + 1
fichier_existe = ExistFile(chemin_fichier)
Wend
End Sub
Something is missing to finish corectly the work ?
thanks for advance.
Goodbye !
Pierre
SolidworksApi macros
