"Insert Volume Goals..." and select the cube. 3. click on "Input Data"-->"Component Control" to turn off the cube. (This makes it a fluid volume" />
Problem creating a fluid volume for a volume goal to operate on.
How does one define a volume for a volume goal?
Imagine the case of a simple pipe flow with a cylindrical internal flow volume.   Now suppose I am interested in a subset of that volume for some analysis goal...say a small cubic fluid space within that pipe.
This is what I've tried:
1. model the cube as a part in the assembly.
2. click on "Goals" -->"Insert Volume Goals..." and select the cube.
3.  click on "Input Data"-->"Component Control" to turn off the cube. (This makes it a fluid volume as far as the calculation is concerned?)
In any case, when I run my analysis, the cube still obstructs the flow as if it's still part of the solid.
I have also tried a second method whereby I modeled the whole project as a part rather than an assembly and created the cube volume as a solid body with the same screwy result.  If I suppress the cube then the flow returns to normal but then I can't use it to define a goal.
Am I missing something basic?
SolidworksFlow Simulation
