I am hoping we have some press brake enthusiasts here. I am a CAD designer who is trying to improve their knowledge of sheet metal forming (mainly air bending on a press brake). The company I work for has recently purchased a press brake to be used for in house prototyping and I have been tasked with overseeing the implementation of it (due to this being the companies first press brake there is no shop floor knowledge or experience I can draw on).
The first thing I want to do is create a document that can be used when designing parts. This is something that can be referred to when designing parts inside Solidworks. I see this document containing the following information,
Punch (top) - XXXX (our top tooling ID)
Die (bottom) - XXXX (our bottom tooling ID)
Material - Stainless Steel
Material Thickness - 1.5mm
Bend Angle - 45degrees
Internal Radius - ???
Bend Deduction - ???
So, I will then know if I am designing a part using 1.5mm stainless steel and add a 45 degree fold I will refer back to my document to find out what internal radius / bend deduction to use.
1. When you take into account the different materials / tooling / angles this is a massive task. Do you think it's worthwhile? I realise that something is required but I don't want to over complicate things. I have found from running physical tests (on 1.5mm stainless) on the machine that I can get parts within a reasonable tolerance (acceptable by our standards) using a k-factor of 0.45 and an internal radius of 1.5mm (i have used this same information on a variety of angles).
2. What is the best process for working out the internal radius / bend deduction? As above I have done physical tests and although working out 90 degree folds is a fairly simple process I don't know where to start when you go above / below 90 degrees. It's very rare that I create a part without an acute / obtuse angle.
Many thanks for any help you can provide.
Paul
SolidworksSheet Metal
