PLC I/O won't generate wire numbers
I've tried the suggestion to change the equipotential formula in wire properties to COR_TNO to force the wire number to be the same as the I/O number. But what I've found is that it forces the wire number to be the same as the terminal number in the PLC. Those numbers cannot be controlled in the PLC properties. If your input address is I:203, for instance, how do I automatically force the wire attached to the terminal to be that number?
SolidworksElectrical
