Hi All ,
I have an issue with Where used function from Solidworks Document Manager API.
I try to fetch the drawing from the Part using where used function. But my return object is nothing.
Code :
Imports SolidWorks.Interop.swdocumentmgr
Imports System
Imports System.IO
Imports System.Diagnostics
Imports System.Collections.Generic
Imports System.Text
Public Class Form1
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Const sLicenseKey As String = "Lickey"
Const sDocFileName As String = "C:\\temp\\Clone_Trail\\Part1.SLDPRT"
Dim dmClassFact As SwDMClassFactory
Dim dmDocMgr As SwDMApplication3
Dim dmDoc As SwDMDocument17
Dim dmDoc2 As SwDMDocument17
Dim nRetVal As SwDmDocumentOpenError
Dim dmSearchOpt As SwDMSearchOption
Dim dmExtRefOption As SwDMExternalReferenceOption
Dim numExtRefs As Integer
Dim value As System.Object
dmClassFact = CreateObject("SwDocumentMgr.SwDMClassFactory")
dmDocMgr = dmClassFact.GetApplication(sLicenseKey)
dmExtRefOption = dmDocMgr.GetExternalReferenceOptionObject
dmSearchOpt = dmDocMgr.GetSearchOptionObject
dmSearchOpt.SearchFilters = (SwDmSearchFilters.SwDmSearchForDrawing)
dmSearchOpt.ClearAllSearchPaths()
dmSearchOpt.AddSearchPath("C:\\temp\\Clone_Trail")
dmDoc = dmDocMgr.GetDocument(sDocFileName, GetDocType(sDocFileName), False, nRetVal)
value = dmDoc.WhereUsed(dmSearchOpt)
End Sub
Private Function GetDocType(ByVal name As String) As SwDmDocumentType
Dim nDocType As SwDmDocumentType = SwDmDocumentType.swDmDocumentUnknown
If name.EndsWith("SLDPRT") Then
nDocType = SwDmDocumentType.swDmDocumentPart
ElseIf name.EndsWith("SLDASM") Then
nDocType = SwDmDocumentType.swDmDocumentAssembly
End If
Return nDocType
End Function
Help is much appreciated !!!!
Regards,
Vignesh N
SolidworksApi macros
