The below code is (to the best of my limited ability) supposed to cycle through all bodies of a part, and rename the faces of each body if they have not yet been renamed. the code works great when I open a part and run it, all faces on all bodies (works if part is a single body or multibody) get renamed.
the issue arises when I go and add a new body to the part (unmerged) and run the code/macro again. It does not cycle through the new body and its faces. please advise, and help is appreciated. see code below:
Dim SW_App As SldWorks.SldWorks
Dim SW_Model As ModelDoc2
Dim Slctn_Mngr As SelectionMgr
Dim Slctn_Data As SldWorks.SelectData
Dim Slctd_Face As Face2
Dim Slctd_Face_Entity As Entity
Dim Slctd_Face_Name As String
Dim Crrnt_Cmpnt As SldWorks.PartDoc
Dim vSW_Body As Variant
Dim Bool_Rtrn As Boolean
Dim Body_Vrnt As Variant
Dim Cmpnt_Name_S1 As String
Dim Cmpnt_Name_S2 As String
Dim vBody_Arr As Variant
Dim Bodies_Cnt As Integer
Dim Face_Cnt As Integer
Dim instnc As Long
Sub Rename_All_Faces_Main()
Set SW_App = Application.SldWorks
Set SW_Model = SW_App.ActiveDoc
'// test code for renaming all faces.
'Clear selections.
SW_Model.ClearSelection2 True
'Get all Bodies
Set Crrnt_Cmpnt = SW_Model
'Clear selections.
vBody_Arr = Crrnt_Cmpnt.GetBodies2(-1, False)
Iterate_Through_Bodies_And_Faces SW_Model, vBody_Arr
End Sub
Sub Iterate_Through_Bodies_And_Faces(SW_Model As SldWorks.ModelDoc2, vBody_Arr As Variant)
Bodies_Cnt = 1
Face_Cnt = 1
For Each vSW_Body In vBody_Arr
'Get count of all faces on body.
Set Slctn_Mngr = SW_Model.SelectionManager
Set Slctn_Data = Slctn_Mngr.CreateSelectData
'Body_Vrnt = Crrnt_Cmpnt.GetBodies2(swAllBodies, True)
'Set vSW_Body = Body_Vrnt(0)
Set Slctd_Face = vSW_Body.GetFirstFace
Cmpnt_Name_S1 = Crrnt_Cmpnt.GetTitle
Cmpnt_Name_S2 = Replace(Cmpnt_Name_S1, ".SLDPRT", "")
'Debug.Print "Component Name S2 (No Doc Extnsn) = " & Cmpnt_Name_S2
'Clear selections.
'Loop for renaming faces.
Do While Not Slctd_Face Is Nothing
Set Slctd_Face_Entity = Slctd_Face
'Select using IEntity.
Bool_Rtrn = Slctd_Face_Entity.Select4(True, Slctn_Data)
'Check if face already named.
Slctd_Face_Name = Crrnt_Cmpnt.GetEntityName(Slctd_Face_Entity)
'Check if face not yet named, skip if already renamed.
If Not Slctd_Face_Name = "" Then
Face_Cnt = Face_Cnt + 1
Else
Bool_Rtrn = SW_Model.SelectedFaceProperties(0, 0, 0, 0, 0, 0, 0, True, Cmpnt_Name_S2 & " - FACE" & Face_Cnt)
End If
Set Slctd_Face = Slctd_Face.GetNextFace
Loop
Bodies_Cnt = Bodies_Cnt + 1
Next vSW_Body
End Sub
