I want to test a linear displacement piston pump at different drive forces applied with the flow simulator to determine exit flow rates and pressures. This will require a variable force applied to the pump head along with a flow simulations through the pump. Ideally the end goal will be to add a second piston into the flow path and attempt to synchronize exit flow rates to lower pulsation caused by pumping. Is that possible?
SolidworksSimulation
