Is there a method to project a sketch onto a curved surface with multiple faces so that the extrude cut feature can be used.
Using an offset plane, I have been able to extrude cut a sketch into the curved surface using the Offset from Surface option. However, when I attempt to change the draft angle for the cut, the draft angle starts from the plane and not the surface. Is there a way around this so that the draft angles start at the surface? Thanks in advance!
SolidworksParts And Features
