Is it possible to bump a revision level on individual sheets within a detail drawing?
I wanted to know if it is possible to bump revision level on individual sheets within a detail drawing using Enterprise PDM. I only have experience using individual detail drawings per part and I wanted to know if there was a better way of doing this as it seems a bit cumbersome to do for every single part.
Example: A detail drawing with 4 sheets in it, each sheet has a different part on it. I want to bump the revision level to REV A on Sheet #2 only, I make the change in the rev box and check the detail drawing into Enterprise PDM. When I increment the revision using Enterprise PDM, is there a way to isolate JUST sheet #2, or will I have to increment a revision on the entire detail drawing and bump it every time I need to make a revision change to one of the sheets within the detail drawing.
