Using SW Inspection; the label or ID assigned to each inspection dimension is fixed. The format is a whole number.
This field format is read only and cannot be modified. If there is a way to change the start "number" I have not been able to find it. You can click in the Start Number parameter field and delete "1" and put in a different start number, but it will not allow a non numerical value.
I have never seen a dwg that didn't have letter labels and for good reason.
These numerical labels are standing beside a numerical dimension. If you are looking at a printed black and white dwg, it is very difficult to tell the label from the dimension in some cases.
Who thought this was a good idea????
Do any of you reading this have a hack or edit for SW .dat or .ini files that allows you to change this default to a letter?
Image; label is in red. If a dimension doesn't have a prefix, and the label is too close, it looks like it is part of the dimension.
