So, here is what i'm trying to do. I'm not sure if Motion can be used to do this or not.
I am designing a Pinewood Derby Car. I've created the car, the track, created the path mates and can simulate the car moving down the track's path
What i want to do, is determine what the velocity is of the car as i make modifications to it. Basically, i want to calculate the time it takes the car to travel down the track after each theoretical modification. This would allow me to study the effects of general weight placement in the vehicle, and overall design modifciations that COULD result in better performance.
I understand that this will not correlate to reality, as I cannot account for friction forces acting against the car, but this will allow me to study the effects on speed that design changes have in a relative manner.
Any ideas?
I thought this might be a fun project, and so i've been trying to work on it.
Thanks for any and all help!
Jeremiah
SolidworksMotion Studies
Hi Jeremiah,
I think you can do what you want. You can set up a proximity sensor when the car reaches the end of the track. Then you can run an event based motion simulation and take some action when the sensor is activated. For example, you can stop the simulation. You can see the time at which the event got triggered - an orange key will be automatically created in the timeline view. You can note down the time at which the event was triggered for every design iteration.
Hope this helps,
Thanks,
Shrikant
Shrikant,
Thank you for your reply. I'm curious how to affect the motion in this way?
I can add gravity to the motion analysis, but without applying a force how will the vehicle move down the ramp?
I'm not a motion expert, what would the best way to set up this type of motion analysis be?
Thanks,
Jeremiah
Hi Jeremiah,
I am not sure what your question is. From your original post, it appeared that you were able to get the desired motion by using gravity. Are you not able to move the car with just gravity? Even if you have to add a force to get the desired motion, there is no reason why you cannot add a proximity sensor as well. Which version of SW do you have - Professional or Premium? Also do you also have SW Simulation? If yes, which version Standard, Professional or Premium? For "Motion Analysis" you need at least SW-Premium. For "Event Based Motion" you need SW-Simulation Professional.
Thanks,
Shrikant
Shrikant,
I have Solidworks Premium, I am not sure that I have Simulation pro, I think I may only have Simulation Standard.
I can do animation, simulating the motion of the car down the track, but i cannot get it to power itself using only gravity to travel down the track.
I'm new to motion analysis, and so I'm sure it is a lack of knowledge on my part that is causing the issue.
Do you have any suggestions for making the car travel down the track using only the forces of gravity?
Thanks,
Jeremiah
Jeremiah,
You need to first make sure that your model is correctly defined for what you want to achieve.
If there are no large frictional forces opposing the motion, then you should be able to move the car under gravity assuming the interaction between the wheels and the track is defined properly.
The interaction would depend upon what you want to achieve - do you want to see the wheels turning or are you ok with them just sliding on the track? If you want to see the wheels turning, it would be a bit more complicated - either you need contact between the road and the wheels or you can define a combination of mates in such a way that as the wheels rotate the car moves. If you are ok with the wheels just sliding, then you can get away with just the mates. Note that, getting contact to work is more difficult than getting the mates to work.
To cause the car to move, apart from gravity, you can also add an external force on the car. But this will cause acceleration of the car which you may not want. Another option is to define initial velocity on the car body in the proper direction.
So it all depends upon what you want to do. I would suggest that you start with the simplest model and get it to work. You can always make the model progressively more complex.
Without knowing the exact details about your model, it is hard to give more concrete directions. If you want to post the model or a picture of the model that would help.
Regards,
Shrikant
Shrikant,
I have attached a zip of a pack and go of all the components. The track is crude mock up of the track used in competitions.
I do not need to see motion in the wheels, they can just "slide" along. All i am concerned with is judging the effects of geometric, and weight placement changes on the car model, in respect to how fast it travels down the track to the end.
I.e. I am concerned with determing the effects of theoretical changes to weight placement, and center of gravity changes on the speed of the car under gravity power.
Does this make sense?
Thanks again!
Jeremiah
Hi Jeremiah,
Here's a motion study that does the simulation you wanted. If you don't have SW-Simulation, the easiest way for you is to find the time taken by a reference point on the car to travel a distance equal to the horizontal dimension of the track. I added a sample plot to show this. You will have to measure the time manually from the plot - either by setting the proper Y-range or by exporting the curve to a csv file and reading from it.
Hope this helps,
Regards,
Shrikant
Thank you Shrikant, that is exactly what I was looking for. I am testing this with multiple models now!
Thank you again,
Jeremiah
