How to Remove "VB Addin" drop down from the command manager
Hi Eeveryone
When creating a SW Addin using the API SDK, the command manager has two commands: Create Cube and Show PMP. It also shows a "VB Addin" drop down menu which includes the exact same two commands.
I cannot seem to be able to remove the "VB Addin" drop down from the command manager.
All I want to see is the Create Cube and Show PMP in the command manager.
Could somebody please put me in the right direction by pointing out the bit of code that I need to Add/Remove to make this happen? I have attached an image to illustrate the issue.
I use VB.NET.
Lots of Thanks
Ali
SolidworksApi macros
