How to reattach balloon using API
use ModelDoc2::EditBalloonProperties→don't reattach balloon.
Description
This method edits the selected balloon's properties
Syntax (OLE Automation)
retval = ModelDoc2.EditBalloonProperties ( style, size, upperTextStyle, upperText, lowerTextStyle, lowerText )
Input:
(long) style
Style of balloon as defined in swBalloonStyle_e
Input:
(long) size
Balloon size as defined in swBalloonFit_e
Input:
(long) upperTextStyle
Upper-text style as defined in swDetailingNoteTextContent_e
Input:
(BSTR) upperText
Text for the upper-text in this balloon
Input:
(long) lowerTextStyle
Lower-text style as defined in swDetailingNoteTextContent_e
Input:
(BSTR) lowerText
Text for the lower-text in this balloon
Return:
(LPDISPATCH) retval
Pointer to the balloon  being edited
2010 SOLIDWORKS API Help - Insert Autoballoons Example (VBA) (AutoBalloon2)  http://help.solidworks.com/2010/english/api/sldworksapi/insert_autoballoons_example_vb_autoballoon2_vb.htm
Follow code result is
File = D:\\360安全浏览器下载\\B\\Assem.SLDDRW
  DetailingBalloonsDisplayWithBentLeader   = False
  DetailingBOMBalloonStyle                 = 1
  DetailingBOMBalloonFit                   = 2
  DetailingAutoBalloonLayout               = 1
  DetailingBalloonBentLeaderLength         = 6.25 mm
  Drawing View1
    No balloons added.
code is
' Preconditions:
'       (1) Drawing document is open.
'       (2) Drawing view is selected.
' Postconditions: If autoballoons have not already been inserted in the
'       drawing document and the drawing document is not lightweight,
'       then autoballoons are inserted for each resolved component in the
'       selected drawing view.
Sub main()
    Const swDetailingBalloonLayout_Default As Long = -1
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swDraw                  As SldWorks.DrawingDoc
    Dim swView                  As SldWorks.View
    Dim vNoteArr                As Variant
    Dim vNote                   As Variant
    Dim swNote                  As SldWorks.Note
    Dim swAnn                   As SldWorks.Annotation
    Dim vAttachPos              As Variant
    Dim vAnnPos                 As Variant
    Dim bRet                    As Boolean
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    Set swSelMgr = swModel.SelectionManager
    Set swView = swSelMgr.GetSelectedObject5(1)
    bRet = swDraw.ActivateView(swView.Name): Debug.Assert bRet
    Debug.Print "File = " & swModel.GetPathName
    ' Get autoballoon settings
    Debug.Print "  DetailingBalloonsDisplayWithBentLeader   = " & swModel.GetUserPreferenceToggle(swDetailingBalloonsDisplayWithBentLeader)
    Debug.Print "  DetailingBOMBalloonStyle                 = " & swModel.GetUserPreferenceIntegerValue(swDetailingBOMBalloonStyle)
    Debug.Print "  DetailingBOMBalloonFit                   = " & swModel.GetUserPreferenceIntegerValue(swDetailingBOMBalloonFit)
    Debug.Print "  DetailingAutoBalloonLayout               = " & swModel.GetUserPreferenceIntegerValue(swDetailingAutoBalloonLayout)
    Debug.Print "  DetailingBalloonBentLeaderLength         = " & swModel.GetUserPreferenceDoubleValue(swDetailingBalloonBentLeaderLength) * 1000# & " mm"
    Debug.Print ""
    Debug.Print "  " & swView.Name
    vNoteArr = swDraw.AutoBalloon2(swDetailingBalloonLayout_Default, False)
    ' Returns an empty array if:
    ' *  Balloons already exist in any drawing view on any on sheet in
    '    the drawing document.
    ' *  Drawing document is lightweight.
    ' Returns a note for each resolved component in the selected drawing view.
    If IsEmpty(vNoteArr) Then
        Debug.Print "    No balloons added."
        Exit Sub
    End If
    For Each vNote In vNoteArr
        Set swNote = vNote
        Set swAnn = swNote.GetAnnotation
        vAttachPos = swNote.GetAttachPos
        vAnnPos = swAnn.GetPosition
        Debug.Print "    Text = " & swNote.GetText
        Debug.Print "      Layer        = " & swAnn.Layer
        Debug.Print "      AttachPos    = (" & vAttachPos(0) * 1000# & ", " & vAttachPos(1) * 1000# & ", " & vAttachPos(2) * 1000# & ") mm"
        Debug.Print "      AnnPos       = (" & vAnnPos(0) * 1000# & ", " & vAnnPos(1) * 1000# & ", " & vAnnPos(2) * 1000# & ") mm"
        'bRet = swAnn.SetPosition(vAnnPos(0) + 0.01, vAnnPos(1), vAnnPos(2))
    Next
End Sub
SolidworksApi macros
Answers 2
SA
SA 2016-12-13 Best Answer
Would you be preselecting the balloon and the place you want to re-attach it to?
YN
YN 2016-12-14
Yes. How to re-attach it.
Text Balloon to Item Number Balloon Macro | SOLIDWORKS Forums  https://forum.solidworks.com/message/580980
Option Explicit
Private strNextBalloonValue As String
Sub InsertBalloon()
    Dim swSelMgr As SelectionMgr
    Dim swEntity As Entity
    Dim newBalloon As Note
    Dim swDwgDoc As ModelDoc2
    Dim strCompName As String
    Dim strCompNameAndPath As String
On Error GoTo Err_InsertBalloon
    Set swDwgDoc = swApp.ActiveDoc
    If swDwgDoc Is Nothing Then
        MsgBox "No active document so can't continue", vbExclamation + vbSystemModal, "Insert Balloon"
        GoTo Exit_InsertBalloon
    End If
    If swDwgDoc.GetType <> swDocDRAWING Then
        'not a Dwg so quit
        MsgBox "Current document is not a Drawing so can't continue", vbExclamation + vbSystemModal, "Insert Balloon"
    Else
        'is a dwg
        Set swSelMgr = swDwgDoc.SelectionManager
        If swSelMgr.GetSelectedObjectCount2(0) <> 2 Then
            'other than 2 objects selected - 1st is the view 2nd is the Entity (face,edge,etc.)
            MsgBox "One Entity to be selected only before using this function", vbExclamation + vbSystemModal, "Insert Balloon"
        Else
            '2 objects selected (1st is the view 2nd is the face or edge of the Part)
            Dim swSelType As swSelectType_e
            swSelType = swSelMgr.GetSelectedObjectType3(2, 0)
            Select Case swSelType
                Case swSelFACES, swSelEDGES, swSelSILHOUETTES, swSelVERTICES
                    'is a Face, Edge, etc
                    Set swEntity = swSelMgr.GetSelectedObject6(2, 0)
                    'get the component which owns the entity
                    Dim swSelectedComponent As Component2
                    Set swSelectedComponent = swEntity.GetComponent
                    'get the name and path for checking later for Bought Out
                    strCompName = Mid(swSelectedComponent.Name, 1, InStrRev(swSelectedComponent.Name, "-") - 1)
                    strCompNameAndPath = swSelectedComponent.GetPathName
                    'get the model which defines the component
                    Dim swSelectedModel As ModelDoc2
                    Set swSelectedModel = swSelectedComponent.GetModelDoc2
                    'was the model already loaded?
                    Dim bLoadedByMe As Boolean
                    If swSelectedModel Is Nothing Then
                        'Get the document specification to load the model
                        Dim swDocSpec As DocumentSpecification
                        Set swDocSpec = swApp.GetOpenDocSpec(swSelectedComponent.GetPathName)
                        'you may not want the user to notice the model opening...
                        swApp.DocumentVisible False, swDocSpec.DocumentType
                        'open the model
                        Set swSelectedModel = swApp.OpenDoc7(swDocSpec)
                        'set yourself a reminder to close the model
                        bLoadedByMe = True
                        'make sure all document open visible after this
                        swApp.DocumentVisible True, swDocSpec.DocumentType
                    End If
                    If Left(strCompNameAndPath, 3) = "S:\" Or Left(strCompName, 3) = "BO_" Then
                        'Bought Out Part so start from 100
                        If strNextBalloonValue = "" Then
                            '1st time so start from 100
                            strNextBalloonValue = "100"
                        Else
                            'not the 1st time so increment number
                            If IsNumeric(strNextBalloonValue) Then
                                strNextBalloonValue = CStr(CInt(strNextBalloonValue) + 1)
                            End If
                        End If
                        strNextBalloonValue = InputBox("Balloon Value?", , strNextBalloonValue)
                        Set newBalloon = swDwgDoc.InsertBOMBalloon2(swBS_Circular, swBF_Tightest, swBalloonTextCustom, strNextBalloonValue, swBalloonTextCustom, "")
                    Else
                        'treat component as Lambert Part
                        'check your property here...
                            Dim strProp As String
                            strProp = swSelectedModel.CustomInfo2("", "LE_DWGNO")
                            If strProp = "" Then
                                'property missing
                                Set newBalloon = swDwgDoc.InsertBOMBalloon2(swBS_Underline, swBF_Tightest, swBalloonTextCustom, "**MISSING PROPERTY**", swBalloonTextCustom, "")
                            Else
                                'property exists
                                Set newBalloon = swDwgDoc.InsertBOMBalloon2(swBS_Underline, swBF_Tightest, swBalloonTextCustomProperties, "LE_DWGNO", swBalloonTextCustom, "")
                                Dim doubleQuote As String
                                doubleQuote = Chr(34)
                                newBalloon.PropertyLinkedText = "$PRPMODEL:" & doubleQuote & "LE_DWGNO" & doubleQuote
                            End If
                        End If
                    If bLoadedByMe Then
                        swApp.QuitDoc swSelectedModel.GetTitle
                    End If
                Case Else
            End Select
        End If
    End If
Exit_InsertBalloon:
    On Error Resume Next
    swDwgDoc.ForceRebuild3 True
    Set swApp = Nothing
    Set swSelMgr = Nothing
    Set swEntity = Nothing
    Set newBalloon = Nothing
    Set swSelectedComponent = Nothing
    Set swSelectedModel = Nothing
    Set swDocSpec = Nothing
    Set swDwgDoc = Nothing
    Exit Sub
Err_InsertBalloon:
    MsgBox Err.Number & " (" & Err.Description & _
                ") in procedure InsertBalloon of modMacros", vbExclamation + vbSystemModal
    Resume Exit_InsertBalloon
End Sub
Reattach balloon using API | SOLIDWORKS Forums  https://forum.solidworks.com/message/672842#comment-672842
2012 SOLIDWORKS API Help - Insert and Show BOM Table and BOM Balloon Example (VBA)  http://help.solidworks.com/2012/english/api/sldworksapi/Insert_and_Show_BOM_Table_and_BOM_Balloon_Example_VB.htm
Add a balloon to a component in drawing | SOLIDWORKS Forums  https://forum.solidworks.com/message/568282
How to move Arrow point of Note (balloon)? | SOLIDWORKS Forums  https://forum.solidworks.com/message/498045
How do I get all position of balloon in the dra... | SOLIDWORKS Forums  https://forum.solidworks.com/message/348900
