How to Provide Assembly Binding Redirects for Solidworks PDM Task Add-ins?
I'm developing a custom PDM task and encountering an assembly binding issue. When I register my DLL, the Solidworks PDM Task Executor looks for a version of System.Numerics.Vectors that isn't referenced in my project. My dependencies require different versions of this library, so I use a .config file with binding redirects to resolve version conflicts during development.
For further context, I also have added a method to my Addin, along with a static constructor registering this resolver to this:  AppDomain.CurrentDomain.AssemblyResolve event handler.
        private static Assembly CurrentDomain_AssemblyResolve(object sender, ResolveEventArgs args)
            try
                string assemblyName = new AssemblyName(args.Name).Name;
                // Get the directory where this add-in is located
                string addinDirectory = Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location);
                string assemblyPath = Path.Combine(addinDirectory, assemblyName + ".dll");
                if (File.Exists(assemblyPath))
                    return Assembly.LoadFrom(assemblyPath);
                // Try alternative paths for dependencies
                string[] possiblePaths = new string[]
                Path.Combine(addinDirectory, "Dependencies", assemblyName + ".dll"),
                Path.Combine(addinDirectory, "lib", assemblyName + ".dll"),
                Path.Combine(addinDirectory, "bin", assemblyName + ".dll")
                foreach (string path in possiblePaths)
                    if (File.Exists(path))
                        return Assembly.LoadFrom(path);
                // For System.* assemblies, try to load from GAC or .NET framework
                if (assemblyName.StartsWith("System.") || assemblyName.StartsWith("Microsoft."))
                    try
                        return Assembly.Load(args.Name);
                    catch
                        // Try loading just the simple name
                        try
                            return Assembly.Load(assemblyName);
                        catch
                            // Last resort for framework assemblies
                            string frameworkPath = Path.Combine(
                                System.Environment.GetFolderPath(System.Environment.SpecialFolder.Windows),
                                "Microsoft.NET", "Framework64", "v4.0.30319", assemblyName + ".dll");
                            if (File.Exists(frameworkPath))
                                return Assembly.LoadFrom(frameworkPath);
                return null;
            catch (Exception ex)
                // Log to PDM debug output or file
                System.Diagnostics.Debug.WriteLine(\\\$"Assembly resolve failed for {args.Name}: {ex.Message}");
                return null;
        } //resolver for an assembly
My questions:
•    Is there a way to provide Solidworks PDM with a configuration file (such as an app.config or TaskHost.exe.config) so it recognizes these binding redirects when loading my add-in?
•    If not, what is the recommended approach for handling dependency version conflicts in PDM task add-ins?
Any guidance or best practices would be greatly appreciated and Apologies if this is not a good question for this forum.
Thank you.
