I have a cut extrude feature that cuts bodies generated by a linear pattern, I can change the dimensions in the sketch used in the cut extrude feature but cannot change the bodies to cut in the cut extrude feature that the sketch cuts. I think I should use "ModifyDefinition" but am not sure how to use it. I thought modifying an existing feature would be easy to do!
This is the code as far as I got, most of this is a recorded macro.
Any well documented code would be greatly appreciated.
Set swModel = swApp.ActiveDoc
'Set Part = swApp.ActiveDoc
'Change Cut Length Dimension
Dim CutLength As Double
CutLength = 70
Set swDim = swModel.Parameter("D2@FingerCut(Sketch)")
swDim.ISetUserValueIn3 swModel, CutLength, swThisConfiguration
swModel.EditRebuild3
'boolstatus = swModel.Extension.SelectByID2("FingerCut(Sketch)", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
'swModel.EditSketch
'swModel.ClearSelection2 True
'boolstatus = Part.Extension.SelectByID2("D2@FingerCut(Sketch)@LinearPatternCut.SLDPRT", "DIMENSION", 7.10620075633694E-03, -7.43530343786387E-02, -1.08468921758118, 'False, 0, Nothing, 0)
'swModel.SketchManager.InsertSketch True
boolstatus = swModel.Extension.SelectByID2("Cut-Extrude29", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
'Change bodies to be cut
boolstatus = swModel.Extension.SelectByID2("LPattern1[7]", "SOLIDBODY", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = swModel.Extension.SelectByID2("LPattern1[15]", "SOLIDBODY", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = swModel.DeSelectByID("LPattern1[15]", "SOLIDBODY", 0, 0, 0)
boolstatus = swModel.DeSelectByID("LPattern1[7]", "SOLIDBODY", 0, 0, 0)
boolstatus = swModel.Extension.SelectByID2("LPattern1[16]", "SOLIDBODY", 0, 0, 0, True, 8, Nothing, 0)
boolstatus = swModel.Extension.SelectByID2("LPattern1[8]", "SOLIDBODY", 0, 0, 0, True, 8, Nothing, 0)
