How to get a positive BLF when analizing Tanks filled with liquids
I'm performing a (linear) buckling analysis on a tank filled with liquid.
I've fixed its legs and put variable pressure to simulate liquid load:
I'm using shell elements.
In this kind of tanks, the main concern is buckling of the legs, therefore it's important to perform FEA to determine optimal geoemtry and sheet metal thickness.
When I run the analysis I get all negative buckling load factors caused by pressure. Like this:
This tank is going to be emptied very slowly, therefore negative pressure is not expected, and so it won't buckle that way.
I need to find positive buckling load factors, but I can't because the max number of modes you can set is 200. The 200th mode is still negative.
My questions are:
- is there a way to "filter out" negative buckling modes ?
  In frequency for example there's an option to find frequencies above a certain value in order to exclude low frequencies (like rigid body motions). I was wondering if buckling had a similar option.
- Given the limit of 200 modes, how can you calculate positive BLF's
I was thinking about replacing pressure with a remote load with rigid connection: this way you can find some positive BLF's.
My fear is that this would make my buckling load factor results anyway invalid.
Any experiences with this situation or suggestions ?
Alex
SolidworksSimulation
Answers 14
BM
BM 2017-03-10 Best Answer
you could try reversing the load and then hope for a negative one.
AU
AU 2017-03-10
Thank Bill for the suggestion.
I tried it but no luck, the first BLF is positive and with higher modes it increases.
I fear the answer is that linear buckling is a too simplified calculation model for this case and therefore non linear is needed to evaluate buckling.
Am I right ?
Alex
RD
RD 2017-03-10
Hi Alessandro,
Looking at your setup, if you are not interested in buckling of the tank itself then why are you keeping the tank in the analysis?
JJ
JJ 2017-03-11
if your interested in the LEGS why is the THIGH is right there? you could remove to shorten analysis
AU
AU 2017-03-11
Geometry that transfers the load to the legs is thin shells which deforms.
If could use remote load with direct transfer, but I don't think that vertical force plus beding moment respect to the center of mass will accurately describe the kind of force that acts on the legs.
I would rather keep everything to more accurately describe the load and do non linear buckling.
AU
AU 2017-03-11
It's shells, very fast analysys (less than 1 minute on my machine).
JJ
JJ 2017-03-11
if your interested to how the legs will buckle then why do you need the pressure on the tank? The tank should already been designed to hold the internal pressure so the mass of the tank plus the mass of the fluid is the factor that will make your legs to buckle, Hmm if i get what's your thinking.
RD
RD 2017-03-11
The entire model would only serve to stiffen the structure.  If you are looking for a conservative calculation then the legs can readily be analyzed individually.  If you are looking fore a less conservative estimate then you remove most the tank and keep the bottom to 1) apply all the loading to have the moments/forces in the legs calculated, and 2) attach the legs together to provide the additional stiffness the tank will give to the system.
This would remove the problematic section of tank that is showing all your buckling right now.
AU
AU 2017-03-13
Ryan, what you say makes sense, but I don't have any experiments to validate against.
Analysis should be as right as possible at first step.
According to my knowledge, linear buckling analysis is non-conservative (Calculated BLF is higher that the true buckling load).
Since there are so many uncertainties in my analysis I would rather go non linear to make sure analysis is as much accurate as possible and I'm not influencing results by making assumptions on the load on the legs.
Alex
SF
SF 2017-03-14
If you're interested on the legs, remove the vessel walls and concentrate on the legs.
Linear buckling is similar to frequency analysis. You can almost relate natural frequencies to buckling modes.
The stiffness of the walls is much smaller than the stiffness of the legs, and you'll get to many buckling modes before you can see any modes on the legs. As it will happen with frequency.
So the easiest way is to simply isolate the legs. That's one of the main assumptions with FEA. Leave only what you want to analyze.
Now, regarding the legs, the vessel is symmetrical, as are the loads. Without making any study, I would say that the first modes will be: tangential rotation through the center of the vessel, axial up and down displacement. And because the legs are tubes, perhaps some bloating and collapsing of the tubes (like the vessel walls) can also be some of the early modes.
This type of model will collapse if there is an imbalance in the force, or on the support under the legs.
I would advise that you apply the force/pressure in a way that would cause that imbalance, and see the resulting buckling modes.
These analysis should be done with the complete base of the vessel, but without the vessel walls and upper part.
But I also agree with you, and I would rather perform a non linear buckling analysis (arc length method). It would be much more accurate, and you'll probably observe a buckling mode not shown by linear buckling analysis.
And as Ryan said, I would analyze a leg individually with NL analysis, taking advantage of the vessel symmetry.
Look at the take a look at exercise 1 of lesson 3, of the SW Simulation Premium Nonlinear training manual for reference.
BM
BM 2017-03-14
Reducing the model to just the legs if the tank is much less stiff than the legs seems like a sensible idea. I would do a linear buckling estimate of the complete leg assembly with a vertical load to see what sort of modes are likely and then do a NL arc length or displacement control analysis - I doubt there is any snap back that would be of interest and the arc length control has been a bit busted since like 2012 or so - seems to take inordinately long time to solve. They may have addressed it in later releases. Either way, you typically need to add some out of plane displacements/loads in an NL analysis of this type if they will not develop on their own which may not be the case here as the legs look tapered. For other modes to emerge (like an axial rotation) it might be required. It doesn't hurt in any case as they are insignificant in the big scheme of things.  I would add some trivial load to any surface involved in a low order linear buckling mode. This will allow the out of plane forces to develop. I would strongly discourage using any sort of symmetry model as it will suppress any non symmetrical modes, though in this case, if it is leg crippling that initiates the failure it wouldn't matter much. Then again I can't really tell from the image exactly what you are dealing with here in terms of leg construction like whether its an  enclosed tube or 3 plates with a side open.
In other codes there is often a capability to add very small displacements from a frequency analysis or buckling analysis to impose non perfection into a model so that out of plane forces develop naturally. Though, I don't think the jury if fully in on how well it mimics actual imperfection.
CC
CC 2017-03-14
I think everybody needs to back the heck up a step or two.
Simulation DOES NOT WORK for non-Euler buckling in static analysis!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok?
I can't speak to it's non-linear capabilities because I use Nastran, but I would probably start there.
You've been warned.
AU
AU 2017-03-18
Thank you all for your toughts and comments, they all come from sound reasonement and make a lot of sense. I will follow your suggestions.
It was a nice, practical, and constructive conversation on a real design issue that could occur on that type of tanks.
Alex
AU
AU 2017-03-18
Agree, you can find this solution in the KB:
What is the theory used by the linearized buckling analysis of SolidWorks Simulation?
The theory used by the linearized buckling analysis of SolidWorks Simulation is Euler buckling.
Non Linear Buckling
One major difference between nonlinear buckling, and the linear (Eigenvalue) buckling, is that nonlinear buckling phenomenon includes a region of instability in the post-buckling region whereas linear buckling only involves linear, pre-buckling behavior up to the bifurcation (critical loading) point.
