How to edit a specific dimension from a group of selected dimensions in API?
Hello everyone. i hope you are so fine.
i am making a program which requires me to select a lot of dimensions, then modeify some of their properties (tolerance) according to a specified criterion.
i started by making a selection of all dimensions for them i want to change tolerances, then i, get access to each of them accoring to the selection order. the problem is that when i write the editing code, it changes all of them, which required an additional time to loop through them accurately.
i wrote the following code:
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
num = swSelMgr.GetSelectedObjectCount()
If num = 0 Then
           MsgBox ("  Please select one dimension at least to setup its tolerance!")
           Exit Sub
End If
For j = 1 To num
    Set swDispDim = swSelMgr.GetSelectedObject5(1)
    Set swDim = swDispDim.GetDimension
    dimValue = swDim.IGetValue3(swThisConfiguration, 1, "Default")
    dimText = swDispDim.GetText(1)
    MsgBox (dimText)
    If dimValue >= 1 And dimValue < 6 Then
              boolstatus = swModel.EditDimensionProperties2(swTolSYMMETRIC, 0.0001, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
    ElseIf dimValue >= 6 And dimValue < 30 Then
              boolstatus = swModel.EditDimensionProperties2(swTolSYMMETRIC, 0.0002, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
    ElseIf dimValue >= 30 And dimValue < 50 Then
              boolstatus = swModel.EditDimensionProperties2(swTolSYMMETRIC, 0.0003, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
    ElseIf dimValue >= 50 And dimValue < 100 Then
              boolstatus = swModel.EditDimensionProperties2(swTolSYMMETRIC, 0.0004, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
    ElseIf dimValue >= 100 And dimValue < 500 Then
              boolstatus = swModel.EditDimensionProperties2(swTolSYMMETRIC, 0.0005, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
    ElseIf dimValue >= 500 Then
              boolstatus = swModel.EditDimensionProperties2(swTolSYMMETRIC, 0.0006, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
    End If
    boolstatus = swModel.DeSelectByID(swDim.GetNameForSelection(), "DIMENSION", 0, 0, 0)
         Next
SolidworksApi macros
