I would like to know the correct way to set up boundary conditions for a hydraulic turbine, where the water entering the turbine is at approximately 23 PSI, and the pressure at the outlet is simply atmospheric pressure (14.7 PSI). The volume of water is also flowing through the turbine at a rate of 20 ft^3/s.
Here's what I have tried so far:
- Use a total pressure boundary condition for the inlet (23 PSI), and outlet volume flow at the outlet (20 ft^3/s).
- This gave me a negative pressure warning while running the simulation.
- Flip the above. So, inlet volume flow (20 ft^3/s) at the inlet, and total pressure (14.7 PSI, or 1 ATM) at the outlet.
- This didn't give me any warnings, but it doesn't seem correct to me because I didn't specify anywhere that the water is at 23 PSI when it enters the turbine.
My issue seems to lie in the fact that SolidWorks Flow Simulation won't let me specify multiple boundary conditions for one face.
Any help is greatly appreciated.
Josh
SolidworksFlow Simulation
Volume flow rate is determined by the pressure difference between the inlet and outlet.
Assign inlet Volume flow rate, inlet pressure will be calculated.
Assign inlet pressure, volume flow rate will be calculated.
This means that only one assignment can be selected for inlet boundary conditions, volume flow rate or pressure.
