How can i get the wire numbers in ODD or Even Numbering?
I am using a wire group with 2 wires, the first phase wire and another is neutral/ ground.
I want the wire numbering in such a fashion that the single phase wire must be all odd. And ground wires must be even.
I tried modifying from our end and got a result that all phase wires are in odd and ground wires are in even. But the problem is for the first wire under even is undefined. I used the following formula.
IIF(EVEN(EQUIPOTENTIAL_ORDERNO)==true,EQUIPOTENTIAL_ORDERNO)
IIF(ODD(EQUIPOTENTIAL_ORDERNO)==true,EQUIPOTENTIAL_ORDERNO)
So here I got to know that this "IIF" statement works with a syntax 'IIF(CONDITION, TRUE STATEMENT, FALSE STATEMENT)'
Hence we modified the formulae as IIF(ODD(EQUIPOTENTIAL_ORDERNO)==true,EQUIPOTENTIAL_ORDERNO,EQUIPOTENTIAL_ORDERNO+1) and respectively.
So from this above formula, I was getting the things as per the requirement in the 'TEST' window.
But this result is not replicated on schematics.
SolidworksElectrical
