Hi, does solid works simulation software helps in designing submarine(like fluid flow), i.e let say i have closed object filled with air present inside the water at a depth of 'D' length , is there a way to find the acceleration rate with this software ?
I am new to the solidworks simulation software.
Does solid works simulation software helps in designing submarine(like fluid flow), i.e let say i have closed object filled with air present inside the water at a depth of 'D' length , is there a way to find the acceleration rate with this software ? and say if it is filled with water and weight is same as the amount of the displaced water, can we see in software that it is stays in same position?
thanks,
Manjunathan
SolidworksSimulation
