Help with sldworks.comment API
I have code that is looping through the design tree in an assembly and I am looking for a way to mark or flag components that I want to delete at the end of the macro.
I am trying to mark the component with a comment and then loop back through the tree and find the components with the comment, select them and delete them.
Here is a simple piece of code for an example.  I get stuck when setting the comment.  I have everything working to create the comment.  I just need help finding the comment in the component.
Dim swApp                    As SldWorks.SldWorks
Dim swAssy                   As SldWorks.IAssemblyDoc
Dim swPart                   As SldWorks.PartDoc
Dim swDraw                   As SldWorks.DrawingDoc
Dim boolstatus               As Boolean
Dim longstatus               As Long, longwarnings As Long
Dim swModel                  As SldWorks.ModelDoc2
Dim fileerror                As Long
Dim filewarning              As Long
Dim swFeatMgr                As SldWorks.FeatureManager
Dim swSelMgr                 As SldWorks.SelectionMgr
Dim nErrors                  As Long
Dim nWarnings                As Long
Dim swTableAnn               As SldWorks.TableAnnotation
Dim swView                   As SldWorks.View
Dim swCustPropMgr            As SldWorks.CustomPropertyManager
Dim swConfMgr                As SldWorks.ConfigurationManager
Dim SwConfig                 As SldWorks.Configuration
Dim swModelDocExt            As SldWorks.ModelDocExtension
Dim swMate                   As Mate2
Dim swComp                   As SldWorks.Component2
Dim vComps                   As Variant
Dim exttype                  As String
Dim swFeat                  As SldWorks.Feature
Dim swprevFeat               As SldWorks.Feature
Sub main()
    Set swApp = GetObject(, "SldWorks.Application")
Set swAssy = swApp.ActiveDoc
    swComponents = swAssy.GetComponents(True)
    Set swModel = swApp.ActiveDoc
    Set swFeatMgr = swModel.FeatureManager
    Set swFeat = swModel.FirstFeature
  Do Until swFeat.GetTypeName = "Reference"
    Set swFeat = swFeat.GetNextFeature
  Loop
        Debug.Print swFeat.Name
        Debug.Print swFeat.GetTypeName
        swFeat.Select (False)
        swFeat.AddComment ("delete")
Dim swComment As SldWorks.Comment
Dim CommentName As String
Set swSelMgr = swModel.SelectionManager
Set swComp = swSelMgr.GetSelectedObjectsComponent2(1)
Debug.Print swComp.Name
Set swComment = swComp.swSelMgr.GetSelectedObject6
CommentName = swComment.text
        If CommentName <> "" Then
            swModel.EditDelete
        End If
End Sub
SolidworksApi/macros
