I have tried to write a batch plot routine to use Edrawings Axcontrol to plot drawing to PDF's.
The currrent problem is after running a few prints I get HashStack errors...and the program closes.
Can anyone offer me a clue as to how to prevent this.... or a better solution.
Any help appreciated. Thanks.
The basic print call is as follows
For V_x As Integer = 0 To BomDataTable.Rows.Count - 1
If BomDataTable.Rows(V_x).Item("PartNum").ToString.Length = 12 Then
FileName2 = V_SaveFolder & "\\TempJobs\\" & BomDataTable.Rows(V_x).Item("PartNum") & ".SLDDRW"
If System.IO.File.Exists(FileName2) = False Then
MsgBox("File Not Found : " & FileName2)
Continue For
End If
Me.Label4.Text = "Processing : " & BomDataTable.Rows(V_x).Item("PartNum")
Me.Label4.Refresh()
Fname = BomDataTable.Rows(V_x).Item("PartNum")
AxEModelViewControl1.Focus()
AxEModelViewControl1.OpenDoc(FileName2, False, False, True, "")
PDFPRINT2(Fname) 'Call Print Sub
AxEModelViewControl1.CloseActiveDoc("")
System.Threading.Thread.Sleep(1000)
Application.DoEvents()
End If
Me.Label4.Refresh()
Next V_x
Private Sub PDFPRINT2(ByVal Name As String)
V_TPageS = AxEModelViewControl1.SheetCount
For V_x = 1 To V_TPageS + 1 'loop for the .drw files
AxEModelViewControl1.ShowSheet(V_x)
If V_x = V_TPageS + 1 Then
SName = AxEModelViewControl1.get_SheetName(0)
AxEModelViewControl1.ShowSheet(0)
W = AxEModelViewControl1.SheetWidth
H = AxEModelViewControl1.SheetHeight
Else
SName = AxEModelViewControl1.get_SheetName(V_x)
End If
If W = 17 Then
PaperSize = PaperKind.Tabloid
ElseIf W = 11 Then
PaperSize = PaperKind.A4
End If
AxEModelViewControl1.SetPageSetupOptions(EMVPrintOrientation.eLandscape, PaperSize, W, H, 1, 0, "PDFCreator", 0, 0, 0, 0)
AxEModelViewControl1.Print4(False, Name & SName, True, False, False, EMVPrintType.eScaleToFit, 0.0, 0, 0, False, V_x, V_x)
System.Threading.Thread.Sleep(500)
newcount = newcount + 1
Me.Label_PrntIts.Text = newcount
Next
End Sub
SolidworksApi macros
