Help with accessing reference geometry point XYZ data
Writing a VBA script that will spit out XYZ coordinates for all selected reference points in a part file to an Excel spreadsheet.
Here is the script so far. It fails at line 36 with "Object doesn't support this property or method" which tells me that this is not the right way to get the number of selected reference points. I am also not sure on the way I access the XYZ data for the reference points.
So two main unknowns for me:
1) Getting the amount of selected reference geometry points, so I can use this data to repeat a command.
2) How does SolidWorks store XYZ coordinates for reference geometry points?
I'm fairly new to VBA for SolidWorks. If someone could help me out here, that would be greatly appreciated!
- Robert
Dim swApp As Object
Sub main()
Dim swSelMgr As SldWorks.SelectionMgr
Dim swFeat As SldWorks.Feature
Dim swRefPt As SldWorks.RefPoint
Dim refPtArr As Variant
Dim i As Long
Dim xVal As Double
Dim yVal As Double
Dim zVal As Double
Set exApp = CreateObject("Excel.Application")
If Not exApp Is Nothing Then
exApp.Visible = True
exApp.Workbooks.Add
Set Sheet = exApp.ActiveSheet
If Not Sheet Is Nothing Then
Sheet.Cells(1, 2).Value = "X"
Sheet.Cells(1, 3).Value = "Y"
Sheet.Cells(1, 4).Value = "Z"
End If
End If
End If
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
Set swRefPt = swFeat.GetSpecificFeature2
refPtArr = swRefPt.GetRefPoint()
For i = 0 To UBound(refPtArr)
Set swRefPt = refPtArr(i)
xVal = refPtArr(i).X
yVal = refPtArr(i).Y
zVal = refPtArr(i).Z
Sheet.Cells(2 + i, 2).Value = xVal
Sheet.Cells(2 + i, 3).Value = yVal
Sheet.Cells(2 + i, 4).Value = zVal
Next i
End Sub
SolidworksApi/macros
